Logitech Illuminated Keyboard K740 is a slim, elegant keyboard with backlit keys and a soft-touch palm rest to type comfortably - even in the dark.
LOGITECH PERFECTSTROKE KEY SYSTEM
The PerfectStroke key system distributes typing force evenly across the key surfaces making every keystroke quiet, natural and fluid-even if you strike the edge of a key -
BETTER TYPING-DAY OR NIGHT
Convenient typing in low light or in the dark. The illuminated keys are sharp, bright and easy to read -
COMFORTABLE AND QUIET
Whisper-quiet, comfortable typing with the Logitech Perfectstroke key system and a built-in, soft-touch palm rest -
SOFT-TOUCH PALM REST
The built in palm rest has a soft, rubber coating for enhanced comfort. Your hands should move freely and be elevated above the palm rest while you type. In between typing, use the palm rest as a resting place for your wrists. Placing the keyboard flat on the desk helps to keep your wrists in a more neutral (straight) position, but you can also use the tilt legs to adjust the height to suit you -
ELEGANTLY DESIGNED
The keyboard is classic black with a touch of orange to identify the FN functions. A clear transparent strip borders the left, top and right edges and a complementary strip of glossy black separates the keys and the palm rest. Embedded in the glossy black strip, to the right of the keyboard, you will find the Num Lock, Caps Lock and Scroll lock LEDs.Together, these elements add a touch of elegance to your desk -
FULL-SIZE LAYOUT
The keyboard has a full size layout with a number pad and full size arrow keys to navigate your document easily
- Logitech Illuminated K740 - keyboard - UK - orange, classic black Input Device
- Keyboard
- Backlit
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Hot Keys Function
- Internet browsing, multimedia, e-mail, volume
- PerfectStroke, built-in wrist rest, adjustable brightness, height-adjustable feet
- Orange, classic black
- 3-year warranty
- Keyboard
- Backlit
- Interface
- USB
- Hot Keys Function
- UK
- Cables Included
- USB cable - 1.8 m
- Included Software
- Logitech SetPoint
- OS Required
- Microsoft Windows Vista / XP / 7 / 8
- Limited warranty - 3 years
