Logitech Hinge Flexible case any-angle stand iPad Air - Light Brown
Quicklinx: BGX9WS00 Mfr#: 939-000823
An iPad Air case that adjusts to you. Get comfy, Hinge holds iPad at any angle within a 50-degree range. iPad stays firmly in place until you decide to change it.
  • Flexible and durable
    A smooth-gliding hinge makes the case flexible yet durable. Withstands angle adjustments time after time
  • Multi-angle stand - adapts to you
    Hinge precisely sets to any angle within a 50 degree range and holds firmly once in place
  • Easy sharing
    Flip the iPad case to instantly share your screen with coworkers, family or friends
  • Stylish fabric
    Beautiful fabric perfectly fits your style whether you're at home or on-the-go
  • Essential Protection System
    Precision engineered with state-of-the-art materials and cutting-edge manufacturing, Hinge protects iPad from accidental bumps, scratches and spills. Scratch protection for iPad enabled when case cover is closed
  • Camera, microphone and charger holes
    Use the camera, microphone and charger without removing iPad from the case
Logitech Hinge - protective case
Protective case
17.56 cm x 1.45 cm x 24.48 cm
335 g
Material
Polyester
Light brown
17.56 cm
1.45 cm
24.48 cm
335 g
Material
Polyester
Light brown
Carrying Case
Protective case
Protection
Scratch-resistant, spill-resistant
Camera lens cutout, sleeping mode, port cut-outs, adjustable viewing angles
2 years
