Full HD 1080p video that's faster, smoother and works on more computers thanks to the H.264 video standard.
FULL HIGH-DEF 1080P VIDEO CALLING
Make a strong impression when it counts with the premium quality of the C920. Whether you're video calling or recording, you'll appear in clear details and vibrant colors, with fluid video thanks to the Full HD 1030p at 30 frames per second -
FULL HD GLASS LENS
Be seen in amazing clarity and detail thanks to the full HD glass lens and premium autofocus. The five-element glass lens captures razor-sharp, clear images, while the premium autofocus adjusts smoothly and precisely to provide consistent high definition -
BRIGHTER IMAGES
Equipped with automatic HD light correction, the C920 fine-tunes to the lighting conditions to produce bright, contrasted images even if you're in a dim setting -
FULL STEREOPHONICS
Fitted with two microphones, one on either side of the camera, the C920 Pro Webcam is able to capture more realistic sound from every angle, so that your voice comes through sounding natural and clear -
FLEXIBILITY THAT GOES BEYOND BUILT-IN
Small, agile and adjustable, the C920 Webcam brings a whole new angle to video calling, making you look and sound like a pro
- Logitech HD Pro Webcam C920 - web camera
- Web camera
- Audio
- Yes: built-in stereo microphone
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1920 x 1080
- Focus Adjustment
- Automatic
- USB 2.0
- Cables Included
- 1 - USB cable - 1.8 m
- 720p HD video calls, Carl Zeiss optics, Logitech Fluid Crystal Technology, 1080p Full HD video calling on Skype, 1080p Full HD movie recording, Skype compatible
- 2 years warranty
- Microsoft Certification
- Compatible with Windows 7
- Web camera
- Audio Support
- Wired
Camera
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
Lens Construction
- Focus Adjustment
- Automatic
- Computer Interface
- USB 2.0
- Cables Included
- 1 x USB cable - 1.8 m
- Software Included
- Logitech Vid HD
- OS Required
- Microsoft Windows 7 64-bit Edition, Google Chrome OS, Microsoft Windows Vista / 7 / 8 / 10
- Limited warranty - 2 years
