Logitech Harmony Ultimate One - Universal Remote Control
Quicklinx: BGXMWS00 Mfr#: 915-000228
£124.99 ex VAT
£149.98 inc VAT
Your remote, evolved
  • Motion-activated backlit keys and touchscreen
  • Eyes-free gesture control
  • Vibration feedback
  • One-touch Activities for IR devices
  • Rechargeable
Simple to use design
Both the screen and the backlit keys light up when the remote senses motion. A gentle vibration tells you a command is received.
Keep your eyes on your entertainment. Simple swipes and taps change channels, adjust volume, or control playback.
Make it your own
Personalize the 2.4inch color touchscreen with frequently-used commands, Activities, and up to 50 channel Favorites.
Touch an Activity like "Watch a Movie" or "Watch TV" and the right devices switch on with just the right settings.
Power at the ready
The charging station keeps Harmony Ultimate One fully charged and easy to find. No more hunting in the sofa cushions.
Harmony compatibility
Harmony Ultimate One controls up to 15 IR devices and is compatible with over 270,000 models from more than 6,000 brands.
Easy online setup
Harmony Ultimate One set-up takes only a few minutes at myharmony.com. Harmony One users can even import their settings.
What's in the box?
  • IR-based remote control (with rechargeable battery)
  • Charging station
  • USB cable
  • AC adapter
  • User documentation
  • Your remote, evolved
    - Motion-activated backlit keys and touchscreen - Eyes-free gesture control - Vibration feedback - One-touch Activities for IR devices - Rechargeable
  • Simple to use design
  • Make it your own
  • Harmony compatibility
  • Power at the ready
  • Easy online setup
Logitech Harmony Ultimate One - universal remote control
Universal remote control
Infrared
Supported Device Qty
15
Input Device
Keypad, touch screen
Rechargeable
2 years warranty
Infrared
15
Input Device
Rechargeable
Operating System
MS Windows XP, MS Windows 7, Apple Mac OS X 10.6.x or later, MS Windows Vista, Windows 8
AC power adaptor, USB cable, charging stand
Rechargeable
Brand: Logitech
Price Range Ex VAT: 100 - 150
