Your basket is empty
Logitech Harmony Touch Plus
Quicklinx: 9CQKWS00 Mfr#: 915-000203
Hurry, only 2 left in stock!
£115.62 ex VAT
£138.74 inc VAT
Harmony Ultimate gives you all the control you deserve. Control home theater devices behind closed cabinets and walls. Access IR devices as well as Bluetooth game consoles. Even use your mobile phone as a powerful, personal universal remote control.
Exclusive to Harmony Ultimate are unique features that make it especially powerful. Double the number of buttons by programming them for both short and long presses. See in dark rooms thanks to the tilt sensors that automatically light up the touch screen. And gentle vibrations let you know when a screen button is pressed, so there's no need to take your eyes off whatever you're watching.
Logitech Harmony Ultimate - universal remote control
Universal remote control
Infrared
Supported Device Qty
15
Supported Devices
Game console, TV / AV System
Input Device
Keypad, touch screen
Wireless Technology
IEEE 802.11b/g/n, Bluetooth
Display
LCD 2.4"
Remote control unit battery rechargeable
2 years warranty
Infrared
Wireless Technology
15
Supported Devices
Input Device
Back-lit buttons, rechargeable
Display
Display
LCD 2.4"
Colour Display
Connector Type
1 x USB (4 PIN USB Type A)
Operating System
MS Windows XP, MS Windows 7, MS Windows Vista, Apple MacOS X 10.4.8 or later, Windows 8, Android 2.3 or later, iOS 5.0 or later
1 x USB cable - external
USB cable, remote control charging stand, 2 AC power adapters, 2 IR Blasters, Harmony Hub
9CQK C2G 2m USB 2.0 A/B Cable - Black In Stock £3.14
9CQK C2G 5m USB 2.0 A/B Cable - Black In Stock £4.52
9CQK C2G 2-Port USB 2.0 Manual Switch In Stock £18.38
9CQK C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.83
9CQK C2G 4-Port USB 2.0 Aluminum Hub In Stock £24.66
9CQK C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.83
9CQK C2G USB Superbooster Extender Kit In Stock £31.09
9CQK C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £49.65
Brand: Logitech
Price Range Ex VAT: 100 - 150
