Logitech Harmony 950 - Universal Remote Control
Quicklinx: CQ52WS00 Mfr#: 915-000260
Bring your living room to life
Tap a custom activity such as "Watch TV" and the right devices power on and automatically switch to the right settings.
  • Control streaming media players like Apple TV, Roku®, and TiVo®, popular gaming consoles, as well as CD, DVD, and Blu-ray™ media players.
  • Teach Harmony 950 new IR commands from other remotes.
  • Works with over 270,000 compatible home entertainment devices from more than 6,000 brands.*
  • Replaces up to fifteen remotes.
Easy-to-use design
Every aspect is designed to make commanding your entertainment easy.
  • Use motion-activated, backlit controls to find the right button every time, even in the dark.
  • Commonly used controls are in easy reach, just below the full-color touchscreen.
  • Change channels, adjust volume, fast-forward, or rewind using gestures on the bright 2.4" touchscreen.
  • Keep your eyes on your entertainment, not your remote, with vibration feedback.
  • Use the sleep timer to fall asleep and let Harmony 950 take care of shutting down.
Power at the ready
Keep Harmony 950 charged and ready with the convenient charging station.
The replaceable battery has 20% greater capacity than previous generation Harmony remotes.
Get started in minutes
Stop using trial-and-error to find remote codes. Add devices simply by entering the device model numbers and brands.
  • Personalize Harmony 950 with your own multi-device, one-touch Activities, up to 50 favorite channels, and frequently used commands.
  • Customize the dedicated media playback, cable/satellite, and DVR controls to your preferences.
  • Create multi-command macros
  • Setup can be completed using an Internet-connected PC or Mac.
What's in the box?
  • Harmony 950 IR-based remote (with rechargeable battery)
  • Charging station
  • USB cable
  • AC adapter
  • User documentation
  • Bring your living room to life
    Tap a custom activity such as 'Watch TV' and the right devices power on and automatically switch to the right settings. - Control streaming media players like Apple TV, Roku , and TiVo , popular gaming consoles, as well as CD, DVD, and Blu-ray media players. - Teach Harmony 950 new IR commands from other remotes. - Works with over 270,000 compatible home entertainment devices from more than 6,000 brands. - Replaces up to fifteen remotes
  • Easy-to-use design
    Every aspect is designed to make commanding your entertainment easy. - Use motion-activated, backlit controls to find the right button every time, even in the dark. - Commonly used controls are in easy reach, just below the full-color touchscreen. - Change channels, adjust volume, fast-forward, or rewind using gestures on the bright 2.4' touchscreen. - Keep your eyes on your entertainment, not your remote, with vibration feedback. - Use the sleep timer to fall asleep and let Harmony 950 take care of shutting down
  • Power at the ready
    Keep Harmony 950 charged and ready with the convenient charging station. The replaceable battery has 20% greater capacity than previous generation Harmony remotes
  • Get started in minutes
    Stop using trial-and-error to find remote codes. Add devices simply by entering the device model numbers and brands. - Personalize Harmony 950 with your own multi-device, one-touch Activities, up to 50 favorite channels, and frequently used commands. - Customize the dedicated media playback, cable/satellite, and DVR controls to your preferences. - Create multi-command macros - Setup can be completed using an Internet-connected PC or Mac
Logitech Harmony 950 universal remote control
Universal remote control
5.4 cm x 3.9 cm x 19.2 cm
163.8 g
Infrared
Supported Device Qty
270000
Input Device
Touch screen
Display
LCD 2.4"
Rechargeable
5.4 cm
3.9 cm
19.2 cm
163.8 g
Infrared
270000
Input Device
Touch screen
Sleep timer, back-lit buttons, vibration feedback
Display
Display
LCD 2.4"
Colour Display
Connector Type
1 x USB (4 PIN USB Type A)
Operating System
MS Windows 7, Windows 8, Apple Mac OS X 10.7 or later, Windows 10
AC power adaptor, USB cable, remote control charging stand
Rechargeable
