Colour smart display
See just what you need, like icons for your favorite channels and the commands you need for the devices you're using. The smart display provides help when you need it.
One-click activity buttons
Simplify your entertainment experience. Once it's set up, just select what you want to do and Harmony 650 does the rest.
Replaces 8 remotes
It's easy to say good-bye to that jumble of remotes on the coffee table.
Intuitive design
Buttons are grouped by their functions, shaped to help you navigate, and backlit so you always know where you are.
What's in the box?
- Remote control
- USB cable
- 2 AA batteries
- User documentation
See just what you need, like icons for your favorite channels and the commands you need for the devices you're using. The smart display provides help when you need it -
Simplify your entertainment experience. Once it's set up, just select what you want to do and Harmony 650 does the rest -
Replaces 8 remotes
It's easy to say good-bye to that jumble of remotes on the coffee table -
Intuitive design
Buttons are grouped by their functions, shaped to help you navigate, and backlit so you always know where you are -
Supports 6000+ brands
Feel confident that Harmony 650 will control the devices you have today and the ones you add tomorrow-whether it's a new Blu-ray player or an aging VCR -
Ever-growing device database
Your remote won't become obsolete when manufacturers release new products or when you buy a new TV or add a Blu-ray player to your setup -
Guided online setup
Connect the remote to your computer and tell us what equipment you have. Our online software walks you through the setup process. 1 -
Brilliant and colourful
See icons for your favourite channels as well as the commands you need for the devices you're using -
Click. Sit back. Enjoy
Just select what you want to do-such as 'Watch a DVD'-and Harmony 650 does the rest -
Setup that's a snap
Connect your remote to your computer. Tell us about your devices. We take care of the hard stuff. Look up your device
- Logitech Harmony 650 Remote universal remote control
- Universal remote control
- 5.84 cm x 22.23 cm x 3.3 cm
- 170 g
- Connectivity Technology
- Infrared
- Supported Device Qty
- 5000
- Display
- LCD
- Battery
- 2 AA type
- 1-year warranty
- 5.84 cm
- 22.23 cm
- 3.3 cm
- 170 g
- Infrared
- 5000
Display
- Display
- LCD
- Colour Display
- Connector Type
- 1 x USB
- Operating System
- MS Windows XP, MS Windows 7, MS Windows Vista, Apple MacOS X 10.4.8 or later, Windows 8
- Included Accessories
- USB cable, 2 AA batteries
- Battery
- 2 AA type
- Limited warranty - 1 year
