Logitech H820e Wireless Mono Headset
Quicklinx: 8YW4WS00 Mfr#: 981-000512
Recommended Use: Computer
Connectivity: Wireless
Earcover : Monaural
11 in stock
£106.29 ex VAT
£127.54 inc VAT
The Logitech Wireless Headset H820e, combines enterprise-quality wireless audio with superior design elements, making it LogitechK's best wireless headset. Interruptions are minimized with a distinct in-call LED light, and muting is intuitive thanks to the on boom mute button and LED mute indicator light.
  • WIRELESS FOR GREATER FREEDOM
    The Logitech H820e Headset stays connected within 100 meters of your desk, with up to 10 hours of wideband talk time. The headset's DECT wireless connectivity won't interfere with Wi-Fi devices in your office
  • ALL-DAY COMFORT
    Enjoy comfort and style. The lightweight, contemporary design of the H820e Headset is complemented by top-quality materials like TR90 nylon, a padded leatherette headband, and replaceable leatherette ear pads to provide many hours of comfort and durability
  • IDEAL FOR BUSY OFFICES
    Phone calls in active work environments can be difficult. The H820e Headset is designed for these situations. The headset automatically pairs with any H820e dock – ideal for hot desking. An LED lets others know you're on the phone, while a visual indicator tells you when you have an incoming call
  • DESIGNED FOR BUSINESS
    The H820e Headset is certified for use with leading conference software applications such as Skype for Business and Cisco Jabber . H820e is recommended for heavy-duty business users in open workspaces, offices, or home offices. Choose H820e Mono or H820e Dual for one or two speakers
  • YES, I'M ON A CALL
    Located on the backside of the boom, an LED indicator provides a visual alert to those behind you that you are on a call, preventing accidental disturbances during calls
  • NOISE & ECHO CANCELLATION
    With acoustic echo cancellation and a noise-cancelling microphone, H820e is optimized so you can hear and be heard, even in noisy workspaces
  • AUTOMATIC PAIRING
    H820e headsets automatically pair when placed in any H820e charger dock, making it easy to use the headsets with any workstation in large deployment or hot desking situations
  • CONVENIENT CONTROLS
    Control the call with on-ear answer/end 1 and volume up/ down buttons. The raised button design provides a point of reference for your fingers so you can feel the buttons you're pressing. Mute and unmute with a tactile button on the adjustable boom
  • HEAR SAFELY
    Logitech Sound Protection protects against sounds above 115 dBA to deliver exceptional listening comfort for voice and music; compliant with EN60950-1
  • WELL-MANNERED WIRELESS
    DECT spectrum wireless connectivity provides exceptional wireless range that won't interfere with Wi-Fi devices in your office. An option to switch between wide and narrow band improves performance in areas of high-density deployment and extends talk time
Logitech Wireless Headset Mono H820e - headset
Headset - DECT - wireless
Recommended Use
Computer
Headphones Form Factor
On-ear
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Audio Specifications
Frequency Response 150 - 7000 Hz - Sensitivity 103 dB
Microphone
Boom
Controls
Mute, volume, answer/end
17.4 cm
5 cm
16.5 cm
88 g
Recommended Use
Computer
Max Operating Distance
100 m
Headphones
On-ear
Headphones Cup Type
Open
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Frequency Response
150 - 7000 Hz
Sensitivity
103 dB
Microphone
Boom
Sensitivity
-45 dB
Frequency Response
100 - 7000 Hz
Total Harmonic Distortion (THD)
10%
Remote Control
Controls
Wireless Link
Transmission Range
100 m
Connector Type
USB (4 PIN USB Type A)
USB charge cable
Charging stand
Headphone battery
Run Time (Up To)
10 hour(s)
Earcover : Monaural
Brand: Logitech
Price Range Ex VAT: 100 - 150
