Logitech H650e USB Stereo Headset
Quicklinx: 8YW7WS00 Mfr#: 981-000519
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
More than 50 in stock
£45.32 ex VAT
£54.38 inc VAT
It is ideal for employees who need to block off surrounding noise for laser-like focus during desktop calls.
Comfortable, stylish and intuitive so people actually love to use them - further enhancing UC collaboration in your workplace.
  • SMART AND STYLISH
    Attention to detail is what distinguishes the Logitech H650e Headset. It's perfect for people who care about design touches like intuitive inline controls for adjusting volume and a bright LED light that lets others know you're on a call. Choose H650e Mono or H650e Stereo for one or two speakers
  • ENTERPRISE-GRADE AUDIO
    The H650e Headset delivers functionality as well as style. This is a pro headset with digital signal processing, acoustic echo cancellation, wideband audio, dynamic equalizer, and noise-cancelling mic. Salespeople and CSRs can make and receive calls with perfect clarity
  • DESIGNED FOR BUSINESS
    Certifications with leading conference software ensure an integrated experience with applications such as Skype for Business and Cisco Jabber . A flat, no-tangle cable connects to the USB port on a Mac or PC for plug-and-play simplicity
  • YES, I'M ON A CALL
    Located on the backside of the boom, an LED indicator provides a visual alert to those behind you that you are on a call, preventing accidental disturbances during calls
  • NOISE & ECHO CANCELLATION
    With acoustic echo cancellation and a noise-cancelling microphone, H650e is optimized so you can hear and be heard, even in noisy workspaces
  • NO-LOOK CONTROLS
    Control the call with answer/end, 1 volume up/down and mute buttons. The volume-up button is strategically built higher than the others, providing a point of reference for your fingers and allowing you to control the call without looking away from your work
  • NO-TANGLE CABLE
    A flat and flexible cable resists tangles so you never get tied up on a call
  • HEAR SAFELY
    Logitech Sound Protection protects against sounds above 115 dBA to deliver exceptional listening comfort for voice and music; compliant with EN60950-1
  • OPTIMIZED FOR VOICE AND MUSIC
    A dynamic equalizer automatically switches between voice and music modes, delivering the best sound quality for what the user is listening to
Logitech USB Headset Stereo H650e - headset
Headset - wired
Recommended Use
Computer
Additional Functions
LED lights
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 50 - 10000 Hz - Sensitivity 90 dB
Microphone
Boom
Microphone Operation Mode
Mono
Controls
Volume, answer/end
3-year warranty
Headset - wired
LED lights
17.4 cm
5 cm
16.5 cm
120 g
Recommended Use
Computer
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Frequency Response
50 - 10000 Hz
Sensitivity
90 dB
In-Cord Volume Control
Microphone
Boom
Mono
Sensitivity
-45 dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Volume, answer/end
Connector Type
USB (4 PIN USB Type A)
Carrying pouch
Cable Details
Headset cable
Limited warranty - 3 years
Connectivity: Wired
Earcover : Binaural
Brand: Logitech
Stock Status: In stock
