The noise-canceling microphone reduces background noise - and rotates out of the way when you're not using it. Why stop at Internet calls? Your headset is ready for music, movies and games, too. You can adjust the headband for the right fit - and wear your microphone on whichever side you want.
Stereo sound
Enjoy clear audio for music, games and calls. A reliable stereo headset for daily tasks including video calls with family or colleagues -
Rotating microphone
Boom can rotate 180° to be worn on the left or right. Flexible mic can be positioned for better voice capture and background noise reduction. Boom can be tucked out of the way when you're not using it -
Adjustable headband
Sturdy yet lightweight stereo headset has a broad range of adjustment. Ultra-soft foam ear cushions provide hours of comfort -
Dual plug connection
Connects to computers that utilize separate 3.5 mm audio jacks for microphone-in and audio-out ports. Not compatible with Chromebook , tablets or Mac
- Logitech Stereo Headset H110 - headset
- Product Type
- Headset - wired
- Recommended Use
- Computer
- Headphones Form Factor
- On-ear binaural
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Built-in - boom
- Microphone Operation Mode
- Mono
- Product Type
- Headset - wired
- Recommended Use
- Computer
Audio Output
- On-ear binaural
- Dynamic
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
Microphone
- Boom
- Mono
- Sensitivity
- -38 dBV/Pascal
- 100 - 16000 Hz
- Connector Type
- Audio line-out (mini-phone stereo 3.5 mm) , Microphone (mini-phone 3.5mm)
- Cable Details
- Headset cable - 1.8 m
