Logitech exclusive Romer-G mechanical switches give you incredible responsiveness, with a key actuation point up to 25 percent shorter. It's faster than standard mechanical switches. Faster actuation means faster response for the edge in battles where every millisecond matters.
EXCLUSIVE ROMER-G MECHANICAL SWITCHES
Logitech exclusive Romer-G mechanical switches give you incredible responsiveness, with a key actuation point up to 25 percent shorter. It's faster than standard mechanical switches. Faster actuation means faster response for the edge in battles where every millisecond matters. Learn more -
INTELLIGENT RGB ILLUMINATION
Use Logitech Gaming software to your keyboard lighting effects. Mark keys by color to keep track of spells and game commands. Each key's backlight can be customized from a palette of approximately 16.8 million colors. The key letters are entirely illuminated for a beautiful, evenly-lit glow. Download Logitech Gaming Software here Learn more -
INTEGRATED ARX CONTROL
Arx Control app introduces second-screen capability. Use your smart phone or tablet to display in-game info, vital system statistics, and in-game control in supported games like Tom Clancy's The Division, and more. The keyboard's adjustable smart dock supports iOS and Android devices -
DEDICATED MEDIA CONTROLS
Take control of your music and videos, using the dedicated media controls to play, pause, and mute. Use the on-board roller bar to adjust the volume. Or, skip to the best scenes at the touch of a button -
9 Customizable G-keys
Orion Spectrum's 9 fully-customizable G-keys can be assigned commands per profile, and have been positioned for optimal speed and accessibility. Up to 27 commands can be stored over the three modes for maximum customizability and convenience. Use Logitech Gaming Software to easily set up and manage profiles and commands. Download Logitech Gaming Software here -
113 KEY ANTI-GHOSTING
Reliably register inputs through even the most strenuous gaming sessions with anti-ghosting protection -
ABSOLUTE COMFORT
G910 features familiar cylindrical keycaps in a layout designed for maximum speed. One large palm rest and adjustable feet ensure that you are in a comfortable position whether typing or gaming
- Logitech G910 Orion Spectrum RGB Mechanical Gaming - keyboard Input Device
- Keyboard
- Backlit
- 16.8 million colours
- Interface
- USB
- Connectivity Technology
- Wired
- Hot Keys Qty
- 16
- Hot Keys Function
- Multimedia, mute, play/pause, stop, previous track, next track, backlight control
- Numeric Keypad
- Key Switch Type
- Romer-G
- 50.5 cm x 21 cm x 3.43 cm
- 1.5 kg
- 2-year warranty
- Keyboard
- Backlit
- Interface
- USB
- Hot Keys Qty
- 16
- Hot Keys Function
- Keyboard Technology
- Mechanical
- Key Switch Type
- Romer-G
- Simultaneous Key Press Quantity
- 113
- Adjustable Height
- Palm Rest
- Numeric keypad
- 50.5 cm
- 21 cm
- 3.43 cm
- 1.5 kg
- Cable Length
- 1.8 m
- Included Accessories
- Large palm rest, ARX control dock
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10
- Limited warranty - 2 years
