Logitech G502 Proteus Core USB EWR2
Quicklinx: BB9GWS00 Mfr#: 910-004076
Proteus Core allows you to change the weight, balance, and enables you to adapt to wherever you choose to play. Customize it to the way you game and make it yours! Fine tune Proteus Core to your playing surface for better accuracy, precision and responsiveness. A quick tuning process, and you are battle ready.
  • Personally-tuned Performance
    Fine tune the optical sensor in Proteus Core to your playing surface for better accuracy, precision and responsiveness. A quick tuning process, and you are battle ready. G502 Proteus Core is pre-tuned for Logitech gaming mouse pads, G240 and G440. Add a mouse pad for extreme accuracy
  • You control the weight and balance
    Customize the gaming mouse to the weight and balance that feels good to you. Proteus Core comes with five 3.6g weights. Add some or all, and arrange their positions for a mouse tailored to you
  • 11 programmable buttons
    You have go-to game commands and macros. Program each of the 11 buttons with your favorites. Save your setting to one of the onboard profiles. Or, select from thousands of profiles on your PC
  • In-game DPI shifting
    Proteus Core helps you be an unstoppable force in low or high DPI. Shift through five DPI settings, from headshot-precise 200 DPI targeting to lightning-fast 12,000 DPI maneuvers
  • Gaming-grade dual-mode, hyper-fast scroll wheel
    You decide the mode with Proteus Core. Choose whether you want click-to-click precision or hyper-fast scrolling
  • Additional Features
    Most accurate sensor on the market 32-bit microcontroller 3 on-board profiles 1 millisecond report rate Primary buttons rated to 20 million clicks Mechanical microswitches Improved keyplate design for better click feeling and performance Braided cable with hook and loop cable tie Sleep mode disabled 3 DPI indicator LEDs Rubber grips Magnetic weight-cavity door
Logitech Proteus Core G502 - mouse - USB
Mouse
Wired - USB
7.5 cm x 13.2 cm x 4 cm
168 g
Movement Detection Technology
Optical
Buttons Qty
11
Movement Resolution
12000 dpi
Performance
40 G maximum acceleration, 300+ inches per second, realtime sensitivity switching 200 - 12000 dpi
Programmable buttons, scrolling wheel, sensitivity adjustment, battery indicator
Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 8.1
3-year warranty
Mouse
7.5 cm
13.2 cm
4 cm
168 g
Input Device
Wired
USB
Optical
Buttons Qty
11
Movement Resolution
12000 dpi
Performance
1 x USB - 4 pin USB Type A
Limited warranty - 3 years
