Logitech G440 Hard Gaming Mouse Pad
Quicklinx: DQX1WS00 Mfr#: 943-000100
G440 features a low friction, hard polymer surface ideal for high DPI gaming, improving mouse control and precise cursor placement. Consistent surface texture can improve sensor performance, especially when used with Logitech G gaming sensors. And the rubber base and hard polymer core help maintain stability.
  • Low friction = high speed
    G440 features ultra low surface friction, offering high DPI gamers an ideal surface for subtle hand movements and quick mouse gestures. The polyethylene surface allows the mouse to move even when applying minimal force, minimizing mistakes from overcompensation when starting or stopping.
  • Consistent surface texture
    Heavy patterns and designs can interfere with sensor performance. G440 features a clean, consistent surface texture. This gives sensors better imagery for translating mouse movement into cursor movement, an improvement over inconsistent or dirty table and desk surfaces.
  • Matched to Logitech G sensors
    G440 can give gamers access to enhanced sensor accuracy and precision. G440 uses a surface texture comparable to the optimal testing environment for Logitech G mice.
  • Stable rubber base
    The only thing sliding on G440 is your mouse. A natural rubber base is firmly bonded to the high-impact polystyrene core, keeping the rigid surface right on the desk where you put it.
  • Multi-layer construction
    G440 is solidly constructed using three critical layers. The polypropylene top layer provides the low-friction surface. A high-impact polystyrene core provides the firm, semi-rigid foundation. And finally, the rubber base keeps the mouse pad stationery.
Logitech G440 - mouse pad
Mouse pad
Product Material
Polystyrene, polymer
34 cm x 28 cm
229 g
3-year warranty
Mouse pad
Product Material
34 cm
28 cm
Thickness
0.3 cm
229 g
Rubber base
Limited warranty - 3 years
