Logitech G430 Headset
Quicklinx: 8X2YWS00 Mfr#: 981-000537
The G430 earpieces have been designed to be slimmer and lighter, without skimping on audio quality. A lighter, balanced assembly means you stay focused on the game. You might even forget you're wearing a headset. You can hear up to seven discrete channels of audio data plus the low-frequency effects (LFE) channel, known as 7.1 surround sound. Dolby Headphone technology perceptually positions each channel in the correct location to reproduce multi-channel content the way developers intended.
  • ON-CABLE CONTROLS
    Adjust the volume or mute in seconds. Audio controls are located on the 2.3-meter cable, so they are always within reach
  • SURROUND SOUNDS AUDIO
    Hear the game the way the developer intended. G430 now comes with both Dolby and DTS Headphone:X surround sound modes. Experience audio with lifelike special awareness as you have never before
  • ROTATING EAR CUPS
    The ear cup pivots for a personalized fit, and rotates 90 degrees to lay flat. The lay-flat design makes them easier to transport and more comfortable when resting around the neck
  • SPORTS-PERFORMANCE EAR PADS
    G430 ear pads are covered with sports-performance cloth for a soft-touch comfort, even after hours of use. Slip off the cloth cover to wash, and keep the headset in top shape
  • LIGHTWEIGHT DESIGN
    Stay focused on the game, not your headset. G430 ear cups are designed to be slimmer and lighter, without skimping on audio quality. You might forget you're wearing them
  • NOISE-CANCELLING MIC
    Be heard loud and clear without the distraction of background noise. Adjust the mic to pick up only your voice
  • ON-CABLE CONTROLS
  • ROTATING EAR CUPS
  • ON-CABLE CONTROLS
Logitech G430 - headset
Headset - 7.1 channel - wired
Recommended Use
Computer
Headphones Form Factor
Full size binaural
Foldable
Wired
Headphones Technology
Dynamic
Sound Output Mode
Surround Sound
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 90 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Technology
Electret condenser
Microphone Operation Mode
Mono
Controls
Volume
3-year warranty
18.4 cm
8.92 cm
18.9 cm
255 g
Recommended Use
Computer
Audio Output
Full size binaural
Foldable
Dynamic
Wired
Sound Output Mode
Surround Sound
Frequency Response
20 - 20000 Hz
Sensitivity
90 dB
Impedance
32 Ohm
Diaphragm
40 mm
In-Cord Volume Control
Microphone
Boom
Electret condenser
Mono
Sensitivity
-40 dBV/Pascal
Impedance
2.2 kOhm
Frequency Response
50 - 20000 Hz
Audio Input Details
Cardioid (uni-directional)
Remote Control
Controls
Volume
Connector Type
Headphones (mini-phone stereo 3.5 mm) , Microphone (mini-phone 3.5mm) , USB (4 PIN USB Type A)
USB adapter
Cable Details
Headset cable - 2.33 m
Limited warranty - 3 years
