The world's fastest gaming mouse. Whether you're lining up a headshot or dodging heavy fire, Hyperion Fury offers the blazing-fast tracking and pinpoint accuracy you need.
Fusion Engine high-speed tracking
Hyperion Fury combines an optical sensor featuring Logitech Delta Zero technology with our exclusive Fusion Engine hybrid sensor to enable tracking speeds in excess of 500 IPS -
8 programmable buttons
Customize your mouse with 8 programmable buttons. Whether you want to toss a grenade or quickly access your inventory, it's at your fingertips. Optional Logitech Gaming Software makes set up easy -
On-the-fly DPI switching
Switch through four DPI settings in an instant. Snipe a foe across the map (250 DPI) before fleeing in the blink of an eye (4000 DPI). With on-the-fly DPI switching, you have the flexibility to react to the chaos of battle with precision -
32-bit ARM processor
Hyperion Fury on-board ARM processor powers the Fusion Engine for incredible tracking speeds while allowing you to save and play back your favorite macros. With Logitech Gaming Software, craft and assign macros that can be accessed from Hyperion Fury with ease -
1ms Report rate
With a 1 millisecond report rate, you can be confident that your movement will be communicated via USB at fast speeds without troublesome lag -
Comfortable design
An update to the classic G400s shape to enhance function and comfort. A combination of lightweight materials and rubber grips will help to ensure that your gaming sessions last as long as possible -
High-speed clicking
Distinct left and right buttons offer extreme responsiveness. With high-speed clicking, you can push your skills even further while enjoying the edge in intense firefights. Faster, more comfortable clicking makes all the difference with Hyperion Fury
- Logitech Hyperion Fury G402 - mouse - USB
- Mouse
- Connectivity Technology
- Wired - USB
- Orientation
- Right-handed
- 7.2 cm x 13.6 cm x 4.1 cm
- 144 g
- Buttons Qty
- 8
- Movement Resolution
- 4000 dpi
- Performance
- 1 ms response time, 16 G maximum acceleration, 500+ inches per second, realtime sensitivity switching 240 - 4000 dpi
- Programmable buttons, rubber side grips, on-the-fly DPI switching with 4 stage LED light indicator, Fusion Engine, ARM 32-bit processor
- OS Required
- Microsoft Windows Vista / 7 / 8 / 8.1
- 2-year warranty
- Mouse
- Orientation
- Right-handed
- 7.2 cm
- 13.6 cm
- 4.1 cm
- 144 g
Input Device
- Wired
- Interface
- USB
- Buttons Qty
- 8
- 4000 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- OS Required
- Limited warranty - 2 years
