The Logitech G35 Surround Sound Headset features game-changing immersion with 7.1 surround sound powered by Dolby technology. Victory never sounded so good.
Dolby Headphone 7.1 surround sound
You'll hear up to seven discrete channels of audio data plus the Low Frequency Effects (LFE) channel-known as 7.1 surround sound. Dolby Headphone software perceptually positions each channel in the correct location to reproduce multi-channel content the way developers intended -
Three programmable G-keys
You've got one-touch control over in-game elements like music, hotkey macros, and more -
A sound advantage
G35 is powered by Dolby Headphone to create an immersive 360-degree sound field that lets you hear what you can't see. Footstep. Enemy fire. Sirens. Because when you have eyes in the back of your head, you win -
Mute light
A glowing red indicator light provides a visual cue to your audio status and keeps you informed when the mic is muted -
Full-speed, all digital USB
In-game sound isn't an effect. It's a critical component of game play. Our USB headphones surround you with aural information. The sound is crisp and clear, and the jack on your sound card stays open for desktop speakers
- Logitech G35 Surround Sound Headset - headset
- Product Type
- Headset - 7.1 channel - wired
- Recommended Use
- Computer
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Surround Sound
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 90 dB
- Impedance
- 32 Ohm
- Microphone Operation Mode
- Mono
- Controls
- Mute, volume
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Product Type
- Recommended Use
- Computer
Audio Output
- Full size
- Wired
- Sound Output Mode
- Surround Sound
- 20 - 20000 Hz
- Sensitivity
- 90 dB
- Impedance
- 32 Ohm
- Diaphragm
- 40 mm
- Magnet Material
- Neodymium
- In-Cord Volume Control
Microphone
- Mono
- Sensitivity
- -42 dBV/Pascal
- 100 - 10000 Hz
- Audio Input Details
- Uni-directional
Remote Control
- Controls
- Mute, volume
- Connector Type
- USB
- Cable Details
- Headset cable - 3 m
- Limited warranty - 3 years
