Logitech G330 Gaming Headset USB - Behind The Neck
Gaming Headset G330
Quicklinx: 64V6WS00 Mfr#: 981-000177
With its adjustable, behind-the-head design, pressure-relieving silicone lining, and pivoting ear pads, the Logitech Gaming Headset G330 delivers comfort that won't quit.
Adjustable, behind-the-head fit
It gives you a lightweight, personalized fit--the first of its kind in gaming headsets.
Comfortable design
The silicone-lined headband with pivoting ear pads relieves pressure so you can stay comfortable for hours.
Noise-canceling mic
It reduces annoying background noise for clear, intelligible voice commands.
Flexible, rotating boom
You can position the microphone right where you want it--and rotate it out of the way when you're not using it.
USB adapter
You've got options--connect digitally to any USB port for enhanced audio or directly to your PC sound card via 3.5 mm jacks.
Inline audio controls
You can adjust the volume or mute the microphone without pausing the action.
Durable headband construction
The spring-steel core is strong yet flexible.
Low-profile speaker drivers
You'll enjoy more accurate sound thanks to the neodymium magnets.
Optimized EQ
When you're connected via USB, it gives you enhanced audio with higher highs and lower lows.
Cable management wrap
Don't need the whole cable? You can wrap it up and keep it out of the way.
  • Adjustable, behind-the-head design
    Provide a lightweight, personalized fit - the first of its kind in gaming headsets.
  • In-line audio controls
    Let you mute or adjust the volume without pausing the action.
  • Flexible, rotating boom
    Lets you position the microphone right where you want it and move it out of the way when you're not using it.
  • Noise-canceling microphone
    Reduces annoying background noise and helps keep your voice clear.
  • Low profile speaker drivers
    Contain neodymium magnets for more accurate sound.
  • Optimized EQ
    Delivers enhanced audio when connected via USB for higher highs and lower lows.
Logitech Gaming Headset G330 - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
Behind-the-neck mount - binaural
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 40 - 18000 Hz - Sensitivity 94 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Mono
Controls
Mute, volume
Microsoft Certification
Compatible with Windows 7
Headset - wired
Recommended Use
Computer
Audio Output
Dynamic
Wired
Sound Output Mode
Stereo
Frequency Response
40 - 18000 Hz
Sensitivity
94 dB
Impedance
32 Ohm
Diaphragm
30 mm
Magnet Material
Neodymium
In-Cord Volume Control
Microphone
Boom
Mono
Sensitivity
-44 dBV/Pascal
Impedance
2.2 kOhm
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Mute, volume
Connector Type
Headphones (mini-phone stereo 3.5 mm) , Microphone (mini-phone 3.5mm)
Headset USB adapter
Cable Details
Headset cable - 2.4 m
Resources
The following resources are available for the Logitech G330 Gaming Headset USB - Behind The Neck
