Logitech G230 Gaming Headset - PC
Quicklinx: 8X30WS00 Mfr#: 981-000540
G230 delivers high-quality stereo sound to keep you immersed in your game from start to finish with earpieces designed to be slim and light, without skimping on audio quality. Logitech covered the G230 ear cups with carefully selected sports performance cloth for a comfortable, soft touch even after hours of use.
  • GAME-QUALITY STEREO SOUND
    Games aren't just about graphics. Sound completes the picture. Using 40 mm neodymium drivers, G230 delivers high-quality stereo sound to keep you immersed in your game from start to finish
  • SPORTS PERFORMANCE CLOTH EAR CUPS
    Marathon gaming sessions mean heat and sweat. We covered the G230 ear cups with carefully selected sports performance cloth for a comfortable, soft touch even after hours of use. And they slip off easily for washing to keep the headset in top shape
  • LIGHTWEIGHT DESIGN
    Earpieces have been designed to be slim and light, without skimping on audio quality. A lighter, balanced assembly means you stay focused on the game. You might even forget you're wearing a headset
  • FOLDING, NOISE-CANCELLING MIC
    When you want to be heard, you will be-loudly and clearly. The G230 noise-cancelling mic can be positioned to pick up your voice alone. Don't feel like talking? Easily fold it up and out of the way
  • ON-CABLE CONTROLS
    Keep the mute switch and volume dial close at hand for quick, precise audio adjustments. All attached to an extra long, 2.3-meter cable
  • LAY-FLAT EARPIECES
    We know even twin gamers are one-of-a-kind. For a personalized fit, the earpieces swivel up to 90 degrees. And because they can turn to lay flat, they're less prone to breakage from everyday wear and tear
  • ON-CABLE CONTROLS
Logitech G230 Stereo Gaming Headset - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
Full size binaural
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 90 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Mono
Controls
Mute, volume
3-year warranty
Headset - wired
Recommended Use
Computer
Audio Output
Full size binaural
Dynamic
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
90 dB
Impedance
32 Ohm
Diaphragm
40 mm
In-Cord Volume Control
Microphone
Boom
Mono
Sensitivity
-40 dBV/Pascal
Impedance
2.2 kOhm
Frequency Response
50 - 20000 Hz
Remote Control
Controls
Mute, volume
Connector Type
Headphones (mini-phone stereo 3.5 mm) , Microphone (mini-phone 3.5mm)
Cable Details
Headset cable
Limited warranty - 3 years
