G230 delivers high-quality stereo sound to keep you immersed in your game from start to finish with earpieces designed to be slim and light, without skimping on audio quality. Logitech covered the G230 ear cups with carefully selected sports performance cloth for a comfortable, soft touch even after hours of use.
GAME-QUALITY STEREO SOUND
Games aren't just about graphics. Sound completes the picture. Using 40 mm neodymium drivers, G230 delivers high-quality stereo sound to keep you immersed in your game from start to finish -
SPORTS PERFORMANCE CLOTH EAR CUPS
Marathon gaming sessions mean heat and sweat. We covered the G230 ear cups with carefully selected sports performance cloth for a comfortable, soft touch even after hours of use. And they slip off easily for washing to keep the headset in top shape -
LIGHTWEIGHT DESIGN
Earpieces have been designed to be slim and light, without skimping on audio quality. A lighter, balanced assembly means you stay focused on the game. You might even forget you're wearing a headset -
FOLDING, NOISE-CANCELLING MIC
When you want to be heard, you will be-loudly and clearly. The G230 noise-cancelling mic can be positioned to pick up your voice alone. Don't feel like talking? Easily fold it up and out of the way -
ON-CABLE CONTROLS
Keep the mute switch and volume dial close at hand for quick, precise audio adjustments. All attached to an extra long, 2.3-meter cable -
LAY-FLAT EARPIECES
We know even twin gamers are one-of-a-kind. For a personalized fit, the earpieces swivel up to 90 degrees. And because they can turn to lay flat, they're less prone to breakage from everyday wear and tear -
LIGHTWEIGHT DESIGN
ON-CABLE CONTROLS
LAY-FLAT EARPIECES
- Logitech G230 Stereo Gaming Headset - headset
- Product Type
- Headset - wired
- Recommended Use
- Computer
- Headphones Form Factor
- Full size binaural
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 90 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- Controls
- Mute, volume
- 3-year warranty
- Product Type
- Headset - wired
- Recommended Use
- Computer
Audio Output
- Dynamic
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 90 dB
- Impedance
- 32 Ohm
- Diaphragm
- 40 mm
- In-Cord Volume Control
Microphone
- Boom
- Mono
- Sensitivity
- -40 dBV/Pascal
- Impedance
- 2.2 kOhm
- 50 - 20000 Hz
Remote Control
- Controls
- Mute, volume
- Connector Type
- Headphones (mini-phone stereo 3.5 mm) , Microphone (mini-phone 3.5mm)
- Cable Details
- Headset cable
- Limited warranty - 3 years
