Logitech G213 Prodigy Gaming Keyboard
Quicklinx: DQWLWS00 Mfr#: 920-008091
Recommended Use: Gaming
Type: Keyboard
Wired / Wireless: Wired
Colour: Black
Compatibility: PC
More than 50 in stock
£51.78 ex VAT
£62.13 inc VAT
The G213 Prodigy gaming keyboard features Logitech Mech-Dome keys that are specially tuned to deliver a superior tactile response and performance profile similar to a mechanical keyboard. Mech-Dome keys are full height, deliver a full 4mm travel distance, 50 g actuation force, and a quiet sound operation. The G213 Prodigy gaming keyboard was designed for gaming, featuring ultra-quick, responsive feedback that is up to 4x faster than the 8 ms report rate of standard keyboards and an anti-ghosting matrix that keeps you in control when you press multiple gaming keys simultaneously.
  • Gaming Grade Performance
    The G213 Prodigy gaming keyboard features Logitech Mech-Dome keys that are specially tuned to deliver a superior tactile response and performance profile similar to a mechanical keyboard. Mech-Dome keys are full height, deliver a full 4mm travel distance, 50g actuation force, and a quiet sound operation. The G213 Prodigy gaming keyboard was designed for gaming, featuring ultra-quick, responsive feedback that is up to 4x faster than the 8ms report rate of standard keyboards and an anti-ghosting matrix that keeps you in control when you press multiple gaming keys simultaneously
  • Crisp, Brilliant RGB Lighting Zones
    A modern keyboard with five individual lighting zones in a spectrum of approximately 16.8 million colors. Change colors to match your setup, specific games or just to showcase your favorite colors. Low light leak around the keycaps means more light comes through the lettering, making each key more brilliant and easier to find in the dark. Learn more
  • Spill-Resistant and durable
    The G213 Prodigy membrane and keyframe construction design is built for real life, delivering spill resistance tested to 60ml liquid rating. The result is a keyboard built to contend with the realities of everyday gaming
  • Integrated Palm Rest & Adjustable Feet
    The two-level angle adjustment lets you set your keyboard to the ideal position, while the integrated palm rest relieves discomfort or fatigue, so you can keep playing comfortably round after round
  • Dedicated Media Controls
    Control your background track without pausing the action. G213 features dedicated media controls that can be used to play, pause, and mute music and videos instantly. Adjust the volume, or skip to the next song with a touch of a button
  • Customize with Logitech Gaming Software
    Logitech Gaming Software lets you customize your G213 for added convenience and personalization. Set the RGB lighting, save time by assigning multiple functions to certain keys, and much more. Download Logitech Gaming Software here
Logitech Prodigy G213 - keyboard - UK English
Keyboard
Backlit
16.8 million colours
USB
Layout
UK English
Hot Keys Function
Mute, play/pause, stop, previous track, next track, volume -, volume +
Protection
Spill-resistant
Numeric Keypad
45.2 cm x 218 cm x 3.3 cm
1 kg
Keyboard
Backlit
USB
Input Device
Hot Keys Function
Layout
UK English
Keyboard Technology
Membrane
Adjustable Height
Palm Rest
Protection
Spill-resistant
Numeric keypad
45.2 cm
218 cm
3.3 cm
1 kg
Cable Length
1.8 m
Microsoft Windows 7 / 8 / 8.1 / 10
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Logitech
Price Range Ex VAT: 50 - 100
