Logitech G Pro X Superlight Wireless Gaming Mouse
Quicklinx: H931WS00 Mfr#: 910-005881
Remove all obstacles in the way of winning with our lightest and fastest PRO mouse ever. The new weapon of choice for the world's top esports professional athletes, it weighs less than 63 grams and delivers near frictionless glide. PRO X SUPERLIGHT continues our design philosophy of ZERØ OPPOSITION-our commitment to remove all obstacles to create the purest possible connection between the player and the game.
  • ZERØ OPPOSITION
  • ZERØ OBSTACLES
    A result of our continued collaboration with top esports pros, PRO X SUPERLIGHT is engineered with a single goal-to create the lightest possible PRO wireless gaming mouse while retaining the quality, structural integrity and pro-grade standards that Logitech G delivers. Take first faster than ever
  • ZERØ SHORTCUTS
    Our lightest PRO mouse yet, PRO X SUPERLIGHT is an engineering breakthrough achieving a weight of less than 63 grams-nearly 25% lighter than our standard PRO Wireless mouse. This was accomplished through meticulous engineering to produce extreme weight reduction with zero compromises to performance
  • ZERØ HESITATION
    Focus on nothing but winning with LIGHTSPEED, our innovative, pro-grade wireless technology for responsive performance and robust connectivity
  • ZERØ MISSES
    Logitech G exclusive HERO 25K sensor provides unrivaled precision, speed, and consistency. PRO X SUPERLIGHT delivers extreme accuracy and ultra fine control for complete confidence especially during the intense, split-second moments of tournament play
  • ZERØ RESISTANCE
    Large, zero-additive PTFE feet deliver a smooth glide for a pure, fluid connection with the game
  • CARBON NEUTRAL
    PRO X SUPERLIGHT meets the highest standards in sustainability. It's a fully carbon neutral certified product. Our manufacturing facilities have been reduced to net carbon neutral emissions through the purchase of renewable energy and carbon offsets
  • NVIDIA REFLEX COMPATIBLE
    NVIDIA Reflex is a suite of technologies designed to optimize system latency to achieve the best responsiveness possible for competitive games. Use PRO X Superlight, GeForce RTX 30 Series GPUs, and an NVIDIA G-SYNC display with NVIDIA Reflex to measure and maximize performance with the world's only total system latency analyzer
  • PRO SERIES
    PRO Series gear helps pros take first faster than ever. Designed in collaboration with many of the world's top esports athletes, PRO gear features the latest technology and the most refined performance, so absolutely nothing gets in the way of winning
Logitech PRO X SUPERLIGHT Wireless Gaming Mouse - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
6.35 cm x 12.5 cm x 4 cm
63 g
Wireless Receiver
USB Logitech LIGHTSPEED receiver
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
25600 dpi
Performance
1 ms response time, 40 G maximum acceleration, realtime sensitivity switching 100 - 25600 dpi, report rate: 1000 Hz, 400 ips tracking speed
Gaming
Polytetrafluoroethylene (PTFE) feet, ARM 32-bit processor, HERO sensor, LIGHTSPEED technology
Windows 8 or later, Apple MacOS 10.11 or later
Mouse
Wireless Receiver
Gaming
6.35 cm
12.5 cm
4 cm
63 g
Input Device
Wireless
2.4 GHz
Optical
Buttons Qty
5
Movement Resolution
25600 dpi
Performance
1 x USB - 4 pin USB Type A
Cleaning cloth, receiver extension adapter, USB charging/data cable, grip tape, aperture door with PTFE foot
Lithium polymer
Run Time (Up To)
70 hour(s)
