The thinnest, lightest Folio helps protect iPad mini from accidental bumps, scratches and spills. The Folio doubles as a stand that holds iPad mini in several different positions.
Ultra-thin, ultra-light protection
The thinnest, lightest Folio helps protect iPad mini from accidental bumps, scratches and spills. -
Adjustable stand
The Folio doubles as a stand that holds iPad mini in several different positions. -
SecureLock system
Lightweight, low-profile clips keep the corners of iPad mini firmly fastened to the frame. -
Auto-wake, auto-sleep
Your iPad mini is always at the ready. The Folio wakes iPad mini when you open the cover and puts it to sleep when you close it.
- Logitech Folio Protective Case - protective case for tablet
- Product Type
- Protective case for tablet
- 14.8 cm x 1.4 cm x 21.4 cm
- 182 g
- Carbon black
- 2-year warranty
- 14.8 cm
- 1.4 cm
- 21.4 cm
- 182 g
- Carbon black
Carrying Case
- Protective case
- Recommended Use
- For tablet
- Protection
- Waterproof, scratch-resistant, spill-resistant
- Adjustable viewing angles
- Cover Features
- Stand function
- 2 years
