Logitech Extreme 3D Pro - Joystick - 12 button(s)
Quicklinx: 8X1GWS00 Mfr#: 942-000031
Type: Joystick
Wired / Wireless: Wired
Compatibility: PC
£33.40 ex VAT
£40.08 inc VAT
Seize the day with a joystick that keeps you at the top of your game. Optimal controls personalized for your unique gaming style. Whether you're in an acrobatic dogfight or striking from long range, the high-stability, precise Logitech Extreme 3D Pro gives you the edge on your competition. Experience superior response and control with 12 conveniently placed action buttons, eight-way rubberized hat switch, twist handle, and rapid-fire trigger.
  • Precision twist rudder control
    Research has shown that advanced flying comes down to instincts and reaction time. To assist pilots, our lab boys designed a custom twist-handle rudder for Extreme 3D Pro, resulting in natural one-handed control with a smaller device footprint
  • 12 programmable buttons
    Extreme 3D Pro has every command at your fingertips and exactly where you want it so you can keep your eyes on the horizon. Each programmable button can be configured to execute simple single commands or intricate macros involving multiple keystrokes, mouse events, and more
  • 8-way hat switch
    Quickly and easily switch from points of view to weapons and more-the 8-way hat switch is designed to accurately capture specialized input specific to flight sims
  • Rapid-fire trigger
    Pull the Extreme 3D Pro trigger as fast as you want or need, confident that every twitch of your finger will be captured without missing a beat
  • Comfortable hand grip
    Fly one more mission or take down more enemies in comfort, even after hours of action. Sculpted curves support and form to your hand for hours of comfortable flying
  • Stable, weighted base
    An extensive study has shown that having a joystick sliding all over the place in the thick of the action is detrimental to performance. The heavy base will hold fast without tipping for lifting while you do your thing
Logitech Extreme 3D Pro - joystick - wired
Joystick
Wired
Buttons Qty
12
Controls
8-way hat switch, triggers
Handle rotation
3-year warranty
PC
Joystick
Wired
Buttons Qty
12
Controls
USB
Handle rotation
Microsoft Windows Vista / 7 / 8
Limited warranty - 3 years
PC
Type: Joystick
Compatibility: PC
Brand: Logitech
