Craft is a wireless keyboard with a premium typing experience and a versatile input dial that adapts to what you're making - keeping you focused and in your creative flow.
Complete creative control
Craft is a wireless keyboard with a premium typing experience and a versatile input dial that adapts to what you're making - keeping you focused and in your creative flow. -
Control you need, the moment you need it
The creative input dial adapts to the app you're using - giving you instant access to specific functions for the task at hand. The touch-sensitive control lets you feel your way through your creation - for a more efficient and immersive workflow. -
Smart illumination
Craft breathes to life with a backlighting flourish when it turns on - and the keys light up the moment your hands approach. The backlit keys automatically adjust brightness to suit changing lighting conditions. -
Type with effortless precision
Confidently type on a keyboard crafted for efficiency, stability, and precision. Increased key stability reduces noise and optimizes responsiveness so you feel, but don't hear, every keystroke. The spherical key dishing is crafted for accuracy, and blind navigation details make it easy to orient your fingers so you never miss a key - or a beat.
- Logitech Craft Advanced with Creative Input Dial - keyboard - UK English
- Keyboard
- Backlit
- Interface
- Bluetooth, 2.4 GHz
- Wireless Receiver
- Logitech Unifying receiver
- Layout
- UK English
- Numeric Keypad
- 43 cm x 14.9 cm x 3.2 cm
- 960 g
- 1 year warranty
- Keyboard
- Backlit
- Interface
- Max Operating Distance
- Up to 10 m
- Wireless Receiver
Input Device
- Layout
- UK English
- Numeric keypad
- 43 cm
- 14.9 cm
- 3.2 cm
- 960 g
- Included Accessories
- Charging cable
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.11 or later
- Rechargeable
- Limited warranty - 1 year
