Logitech Corded Keyboard K280e Swiss layout
Quicklinx: BGYZWS00 Mfr#: 920-005218
Recommended Use: Office
Type: Keyboard
Wired / Wireless: Wired
Colour: Black
Compatibility: PC
£18.06 ex VAT
£21.67 inc VAT
The Logitech corded keyboard K280e provides businesses the perfect balance of quality and value. With a reinforced, spill-resistant chassis and low-profile keys designed to withstand up to 10 million keystrokes, the K280e can handle years of heavy office use. The comfortable palm rest will make this keyboard a workforce favorite as well.
  • Heavy-duty reinforced chassis
    Solid construction ensures extended durability and provides for long-term use.
  • Full-size, comfortable palm rest
    Provides extra comfort to keep employees productive throughout the day.
  • Spill-resistant design
    Helps protect your investment from losses caused by common office spills like coffee.
  • Modern, elegant profile
    Sophisticated design helps create an attractive workspace that employees enjoy.
  • Nearly-silent, low-profile keys with smooth action typing
    Ensure comfortable and quiet typing around the office.
  • Keys designed to withstand up to 10 million keystrokes
    Keys are designed to take years of heavy office use, protecting the longevity of your investment.
  • Full-size keyboard layout with shortcut keys
    All computing control tools are intuitively designed for easy reach.
  • High-quality, padded key prints with UV coating
    Prevents letters and numbers from wearing down over time, minimizing employee requests for a replacement keyboard.
  • Tilt legs
    Set the angle of the keyboard so it fits just right.
  • LED notification center
    Visually signals the typing mode - caps, scroll, number lock.
  • USB plug-and-play simplicity
    Works right out of the box for maximum plug-and-play efficiency - no software installation required.
Logitech Corded K280e - keyboard - Swiss Input Device
Keyboard
USB
Wired
Localization and Layout
Swiss
Spillproof, tilt legs, built-in wrist rest
45.9 cm x 18.26 cm x 20.4 cm
930 g
Keyboard
USB
Swiss
45.9 cm
18.26 cm
20.4 cm
930 g
1 x USB cable - 1.7 m
Plug and Play
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7 / 8
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Logitech
