The Logitech corded keyboard K280e provides businesses the perfect balance of quality and value. With a reinforced, spill-resistant chassis and low-profile keys designed to withstand up to 10 million keystrokes, the K280e can handle years of heavy office use. The comfortable palm rest will make this keyboard a workforce favorite as well.
Heavy-duty reinforced chassis
Solid construction ensures extended durability and provides for long-term use. -
Full-size, comfortable palm rest
Provides extra comfort to keep employees productive throughout the day. -
Spill-resistant design
Helps protect your investment from losses caused by common office spills like coffee. -
Modern, elegant profile
Sophisticated design helps create an attractive workspace that employees enjoy. -
Nearly-silent, low-profile keys with smooth action typing
Ensure comfortable and quiet typing around the office. -
Keys designed to withstand up to 10 million keystrokes
Keys are designed to take years of heavy office use, protecting the longevity of your investment. -
Full-size keyboard layout with shortcut keys
All computing control tools are intuitively designed for easy reach. -
High-quality, padded key prints with UV coating
Prevents letters and numbers from wearing down over time, minimizing employee requests for a replacement keyboard. -
Tilt legs
Set the angle of the keyboard so it fits just right. -
LED notification center
Visually signals the typing mode - caps, scroll, number lock. -
USB plug-and-play simplicity
Works right out of the box for maximum plug-and-play efficiency - no software installation required.
- Logitech Corded K280e - keyboard - French Input Device
- Keyboard
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- French
- Spillproof, tilt legs, built-in wrist rest, low profile keys, UV-coated keys
- 45.9 cm x 18.26 cm x 20.4 cm
- 930 g
- Keyboard
- Interface
- USB
- French
- 45.9 cm
- 18.26 cm
- 20.4 cm
- 930 g
- Cables Included
- 1 x USB cable - 1.7 m
- Plug and Play
- OS Required
- Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7 / 8
