The Logitech Combo Touch keyboard case provides form-fit protection for iPad. The Multi-Touch trackpad enables precise navigation and a detachable keyboard offers flexibility for different tasks. Users can easily type, sketch, view and read, whether they're at their desk or on the go. Combo Touch brings versatility to iPad, enhancing the user experience and promoting productivity anywhere.
TAKE iPAD FURTHER
Power your passion from anywhere. Meet the keyboard case that enables whole new levels of versatility and protection. Multiple use modes allow you to easily type, view, sketch, read and more with Combo Touch for iPad Pro. Possibilities? Endless -
THINNER. LIGHTER
The new Combo Touch is the thinnest and lightest yet; it slips into bags, travels light, and powers your productivity anywhere -
LARGEST TRACKPAD EVER
The biggest trackpad ever made for Combo Touch. Familiar Multi-Touch gesture controls let you swipe, pinch, double-tap, and more -
PREMIUM MATERIALS
Thoughtfully designed with sustainable, premium materials that feel as good as they look. Experience elegance with our sleek, low-carbon aluminum bottom and newly formulated, luxuriously soft-touch textiles -
USE-YOUR-WAY MODES
Multiple use modes and infinite possibilities. Switch it up to type, sketch, watch videos, read, or hop on a video call -
DETACHABLE, FULL-SIZED KEYBOARD
Large, well-spaced keys give your hands plenty of room to type comfortably, while scissor keys give you that perfect bounce. Done typing? Just detach the keyboard to sketch, watch or read with total freedom -
MULTI-TOUCH TRACKPAD
The precise, click-anywhere trackpad provides that superior, intuitive tracking experience you need to make things happen. Familiar Multi-Touch gesture controls let you swipe, pinch, double-tap, and more -
FLEXIBLE KICKSTAND
Find your preferred angle for just about any task with the ultra-flexible kickstand -
SECURE, FORM-FIT PROTECTION
The sturdy and portable case keeps your iPad Pro safe from scuffs and scratches, so you can take it anywhere with total peace of mind -
TYPE AWAY, DAY OR NIGHT
Adjustable backlit keys enable your mood-lit work sessions to be even more enjoyable than ever -
POWER, PAIR, AND CHARGE
Smart Connector technology enables seamless, instant, secure connectivity with no need to charge-it's powered by iPad -
SUPPORTS APPLE PENCIL
Combo Touch is designed to let you attach Apple Pencil right to iPad. No need to remove the case
- Logitech Combo Touch - keyboard and folio case - with trackpad - QWERTY - UK - oxford grey Input Device
- Keyboard and folio case
- Backlit
- 16-level
- Interface
- Apple Smart connector
- Connectivity Technology
- Wired
- Built-in Devices
- Trackpad
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Search, mute, brightness, screen lock, play/pause, previous track, next track, home screen, on screen keyboard, backlight control, volume -, volume +
- Protection
- Bump protection
- Oxford grey
- Case Material
- Woven fabric
- 28.56 cm x 22.57 cm x 1.74 cm
- 780 g
- 2-year warranty
- Designed For
- Apple 12.9-inch iPad Pro (5th generation)
- Backlit
- 16-level
- Interface
- Hot Keys Function
- QWERTY UK
- Built-in Devices
- Trackpad
- Protection
- Bump protection
- 28.56 cm
- 22.57 cm
- 1.74 cm
- 780 g
Carrying Case
- Material
- Woven fabric
- Ports and controls access, protective corners, auto sleep/wake function, Apple pencil holder, 20°-60° adjustable angles, backlit auto-adjusting
- Oxford grey
- OS Required
- Apple iOS 13.4 or later
- Limited warranty - 2 years
- Designed For
