The Logitech C920-C Webcam is the professional webcam that delivers true-to-life HD 1080p quality video. With a 78-degree field of view, UVC H.264 encoding and omnidirectional mics, the C920-C brings high-quality desktop face-to-face collaboration to UC.
HD 1080p 1 video at up to 30 frames per second
Make a vivid impression with true-to-life, high definition video calls -
UVC H.264 encoding technology
Frees up system bandwidth by putting video processing within the camera -
78-degree field of view with true widescreen
See more without having to reposition the camera or crop and zoom -
Logitech RightLight 2 technology and autofocus
Webcam intelligently adjusts to improve visual quality in low light and backlit situations at multiple distances -
Omni-directional dual stereo microphones
Designed to capture sound for clear communication in larger spaces like offices and small conference rooms -
Convenient privacy shutter
Easy lens closure for added privacy and security -
Multiple mounting options
Freedom to mount the camera wherever it works best – LCD screen, notebook, or tabletop – by using the attached clip or the tripod embedded thread -
USB plug-and-play set up
Easy to set up and easy to use -
Designed exclusively for the Cisco Jabber experience
Don't worry about setup or interoperability, this is the only keyboard/webcam/mouse combo exclusively selected and certified by Cisco for seamless integration with Cisco VXC, Jabber and WebEx Meeting Center solutions -
HD 1080p video at up to 30 frames per second
- Logitech Webcam C920-C - webcam
- Webcam
- Audio
- Yes: built-in dual stereo microphones
- 12.6 cm x 4.5 cm x 7.3 cm
- 170 g
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Focus Adjustment
- Automatic
- USB 2.0
- Cables Included
- 1 - USB cable
- USB 2.0 compatibility, RightLight 2 technology, Privacy mode, auto low-light correction, USB 3.0 compatibility, 1080p Full HD movie recording
- 3-year warranty
- Webcam
- Audio Support
- Wired
- 12.6 cm
- 4.5 cm
- 7.3 cm
- 170 g
Camera
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Video Capture
- 1920 x 1080 @ 30 fps
Lens Construction
- Focus Adjustment
- Automatic
- Horizontal Field of View (degree)
- 78
- Computer Interface
- USB 2.0
- 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x USB cable
- UL, FCC, RoHS, WEEE, TUV T
- OS Required
- Microsoft Windows 7, SuSE Linux 11, Apple MacOS X 10.6 or later
- Limited warranty - 3 years
