With HD 720p video calling and recording, as well as one-click HD uploading to Facebook, now you can share your HD world - anywhere, anytime.
WIDESCREEN HD 720P VIDEO CALLS
Make high-definition video calls on your favorite platforms like Skype . At 30 frames per second, video quality is smooth, while images are crisp, colorful and contrasted -
CONSISTENTLY FOCUSED
Fast autofocus means your video stays razor sharp, even if you're moving around, are very close to the webcam or are showing objects and documents (up to 7 cm from the camera lens) -
BRIGHTER IMAGES
Equipped with HD light correction, the C525 fine-tunes to the lighting conditions to produce better quality, brighter images even if you're in a dim setting -
YOUR VOICE IS HEARD
The built-in noise-reducing mic makes sure your voice comes across clearly, even if you're in busy surroundings -
FULL CIRCLE
The C525 swivels a full 360 degrees, gives you more flexibility to get it at the right angle. The fold-and-go design collapses into a compact size that protects the lens so that you can slip the webcam into your bag, purse or even your pocket
- Logitech HD Webcam C525 - webcam
- Webcam
- Audio
- Yes: built-in microphone
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1280 x 720
- Motion Detection
- Focus Adjustment
- Automatic
- USB 2.0
- Cables Included
- 1 - USB cable - 1.5 m
- RightSound technology, RightLight 2 technology, Motion Detection Technology, 720p HD video calls, Logitech Fluid Crystal Technology, digital PTZ function
- 2-year warranty
- Webcam
- Audio Support
- Wired
- Localisation
- EMEA
Camera
- Max Digital Video Resolution
- 1280 x 720
- Motion Detection
Lens Construction
- Focus Adjustment
- Automatic
- Computer Interface
- USB 2.0
- Cables Included
- 1 x USB cable - 1.5 m
- Software Included
- Drivers & Utilities, Logitech Video Effects, Logitech Vid HD
- OS Required
- Microsoft Windows 7 (32/64 bits), Windows 8
- System Requirements Details
- Windows XP/Vista/7 - 1 GHz - RAM 512 MB - HD 200 MB
- Limited warranty - 2 years
