Product
Logitech C525 HD Webcam Black
Quicklinx: C6VTWS00 Mfr#: 960-001064
£36.98 ex VAT
£44.37 inc VAT
With HD 720p video calling and recording, as well as one-click HD uploading to Facebook, now you can share your HD world - anywhere, anytime.
  • WIDESCREEN HD 720P VIDEO CALLS
    Make high-definition video calls on your favorite platforms like Skype . At 30 frames per second, video quality is smooth, while images are crisp, colorful and contrasted
  • CONSISTENTLY FOCUSED
    Fast autofocus means your video stays razor sharp, even if you're moving around, are very close to the webcam or are showing objects and documents (up to 7 cm from the camera lens)
  • BRIGHTER IMAGES
    Equipped with HD light correction, the C525 fine-tunes to the lighting conditions to produce better quality, brighter images even if you're in a dim setting
  • YOUR VOICE IS HEARD
    The built-in noise-reducing mic makes sure your voice comes across clearly, even if you're in busy surroundings
  • FULL CIRCLE
    The C525 swivels a full 360 degrees, gives you more flexibility to get it at the right angle. The fold-and-go design collapses into a compact size that protects the lens so that you can slip the webcam into your bag, purse or even your pocket
Logitech HD Webcam C525 - web camera
Web camera
Audio
Yes: built-in microphone
Wired
Camera
Max Resolution
1280 x 720
Motion Detection
Focus Adjustment
Automatic
USB 2.0
1 - USB cable - 1.5 m
RightSound technology, RightLight 2 technology, Motion Detection Technology, 720p HD video calls, Logitech Fluid Crystal Technology, digital PTZ function
2 years warranty
Web camera
Audio Support
Wired
EMEA
Camera
Max Digital Video Resolution
1280 x 720
Motion Detection
Lens Construction
Focus Adjustment
Automatic
Computer Interface
USB 2.0
1 x USB cable - 1.5 m
Software Included
Drivers & Utilities, Logitech Video Effects, Logitech Vid HD
Microsoft Windows 7 (32/64 bits), Windows 8
System Requirements Details
Windows XP/Vista/7 - 1 GHz - RAM 512 MB - HD 200 MB
Brand: Logitech
Price Range Ex VAT: 0 - 50
