Logitech Bluetooth Illuminated Keyboard K810
Quicklinx: 8F5RWS00 Mfr#: 920-004310
A stylish keyboard with bright, backlit keys and one touch easy-switching between your PC, tablet, and smartphone.
Logitech Bluetooth Illuminated Keyboard K810 -- performance shines through in style.
Laser-etched backlit keys
Type easily in low light and even in the dark. Back lighting ensures the keys are sharp, bright and always easy to read in any light. Only the key characters are illuminated, so you see just what you need to see without distraction.
Auto-adjusting illumination
The illumination automatically adjusts to suit the light conditions in the room. You can also manually adjust the brightness of the illumination using the F5 and F6 keys.
Designed for Windows 8, compatible with Android and iOS
This keyboard has specific keys to help you easily navigate the new Windows 8 style user interface. The Windows 8 Start key provides an easy way to get back to your start screen. The App Switching FN key allows you to quickly toggle between your open apps. Although it was specially designed for Windows 8, this keyboard also works well with Windows 7, iOS and Android operating systems.
Hand proximity detection
A motion sensor detects your hands as they approach the keyboard and turns the backlight on/off to help you save power when you are not typing.
Logitech Easy-Switch™
Press one button to switch in a second between your Bluetooth devices. Logitech Easy-Switch allows you to quickly toggle between typing an email on your Windows® PC, to taking notes on your Apple® iPad®, to replying to a text on your Android™ smartphone.
Reliable Bluetooth connection
Pair the keyboard with your PC, tablet and smartphone easily over Bluetooth. The fast, reliable connection allows you to move and type on the keyboard anywhere within 30 feet (9 meters) of your Bluetooth devices.
Simply stylish
The keyboard case is real, brushed aluminum with a high-grade finish to complement the design, look and feel of today's trendiest PCs, Ultrabooks™, tablets and smartphones.
Sleek and ultra-thin
With sleek lines and low-profile keys, this slim keyboard will be an elegant addition to your workspace.
Compact and wireless
The minimalist, cable-free design takes up much less space on your desk than a full-size keyboard. It also means you can take your keyboard wherever you go with your Ultrabook, tablet or smartphone.
USB rechargability
Forget about having to change batteries. With USB rechargability, you'll never run out of power. Easily top up your keyboard with the convenient USB cable and continue to work. You'll enjoy between 10 days* and up to a year of power, depending on the intensity of illumination and time spent typing.
Power management
On/Off switch on the right side panel helps you conserve power when the keyboard is not in use. There is also a battery indicator light which turns red when you need to power up and green when the keyboard is charging.
Logitech Incurve™ keys
Type comfortably thanks to the unique Logitech keycap design. The concave key surface complements the natural profile of your fingertips and helps you better locate each key for an improved typing experience. The key edges are also softly rounded so your fingertips glide smoothly from key to key.
Logitech PerfectStroke™ key system
The PerfectStroke key system distributes typing force evenly across the key surfaces making every keystroke silent, natural and fluid--even if you strike the edge of a key.
  • Logitech easy-switch technology
    Quick transition from typing on a PC to your tablet or smartphone devices with the push of a single button helps you stay productive while multi-tasking
  • Backlit illumination
    Backlit keys adjust their brightness automatically for efficient typing in any light
  • Rechargeable battery
    A built-in rechargeable battery charges via USB cable, even while in use, and lasts up to ten days from a single charge
  • Smart power management
    Built-in sensors detect when hands approach, turning the keyboard on or off to save power
  • Sleek, compact design
    Thin, minimalist design with brushed-aluminum provides a stylish, space saving option for small workspaces and cubicles
  • Logitech Incurve keys
    Enjoy comfort of a traditional keyboard paired with Logitech's innovative concave key cap design for whisper-quiet typing
  • Dedicated Windows 8 navigation key
    Windows 8 users have the added benefit of quickly toggling between open apps on the new Windows 8 interface
  • Works across multiple platforms
    Designed to work well with Windows , iOS and Android operating systems so there's no delay as you switch between your PC, tablet and smartphone devices
Logitech Illuminated K810 - keyboard - UK
Keyboard
Backlit
Bluetooth
Localization and Layout
Hot Keys Function
Calculator, volume, mute, play/pause
PerfectStroke, Logitech Incurve keys, on/off power switch, low profile keys
29 cm x 12.8 cm x 1.4 cm
338 g
3-year warranty
Keyboard
Backlit
Bluetooth
Max Operating Distance
Up to 10 m
Input Device
Hot Keys Function
29 cm
12.8 cm
1.4 cm
338 g
1 x USB charge cable
Microsoft Windows 7, Apple iOS 4 or later, Windows 8, Android 3.0 (Honeycomb) or later, Windows RT
Installed Qty
1
Lithium polymer
Limited warranty - 3 years
