Logitech B525 HD Webcam MS Lync Optimised
Quicklinx: 7WL7WS00 Mfr#: 960-000842
The Logitech B525 HD Webcam allows you to enjoy clear, 720p HD video calling from either your laptop or on top of your monitor, using your favorite video applications (including Microsoft Lync and Skype). This HD webcam gives you a superior video calling experience at an affordable price.
  • HIGH-QUALITY IMAGE AND SOUND
    Image quality is important for your business meetings. The affordable B525 HD Webcam, with its 720p HD video captured at 30 frames per second, delivers clear images even in low-light conditions. Built-in autofocus maintains sharpness as close as 10 cm
  • EASY TO SET UP AND USE
    Plug and play to start every meeting on time. The B525 HD Webcam works with popular video conferencing software, including Skype and Skype for Business. The convenient fold-and-go design lets you pack the camera and take it with you. Just attach it to your laptop and begin your meeting
Logitech HD Webcam B525 - webcam
Webcam
Audio
Yes: built-in microphone
6.6 cm x 2.9 cm x 4 cm
88 g
Wired
Camera
Max Resolution
1920 x 1080
Focus Adjustment
Automatic (min distance 10 cm)
USB 2.0
1 - USB cable - 1.5 m
USB 2.0 compatibility, RightLight 2 technology, 720p HD video calls, Skype compatible
3-year warranty
Webcam
Audio Support
Wired
6.6 cm
2.9 cm
4 cm
88 g
Camera
Max Digital Video Resolution
1920 x 1080
Video Capture
1280 x 720 , 1920 x 1080
Lens Construction
Focus Adjustment
Automatic
Min Focus Distance
10 cm
Computer Interface
USB 2.0
Interfaces Details
1 x USB 2.0 - 4 pin USB Type A
Flat panel monitor clip
1 x USB cable - 1.5 m
Plug and Play
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Limited warranty - 3 years
