Your basket is empty
Logitech B100 Optical Mouse for Business Black
Quicklinx: 8YW0WS00 Mfr#: 910-003357
Type: Mouse
Wired / Wireless: Wired
Colour: Black
Compatibility: Mac, PC, Unix
More than 50 in stock
£5.41 ex VAT
£6.49 inc VAT
Standard delivery Delivered within 3-5 working days
A comfortable plug-and-play mouse with built-in quality and optical precision!
You'll enjoy smooth, precise cursor control that lets you edit documents and navigate the Web more efficiently.
It works right out of the box - you just plug it into your USB port and you're ready for business.
Left-handed or right, you can work comfortably all day long with this ambidextrous mouse.
You're in control with smooth, responsive optical tracking that moves the cursor just where you want it.
Logitech B100 - mouse - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Scrolling wheel
1 x USB cable - integrated - 1.8 m
Linux 2.4 or later, Microsoft Windows 7, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
Microsoft Certification
Compatible with Windows 7
3 years warranty
Mouse
Orientation
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Scrolling wheel
1 x USB - 4 pin USB Type A
Plug and Play
Limited warranty - 3 years
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
Brand: Logitech
Price Range Ex VAT: 0 - 50
