Logitech 960-001063 HD Webcam C270 - Web Camera
Quicklinx: C7NCWS00 Mfr#: 960-001063
£25.88 ex VAT
£31.05 inc VAT
Sharing, socializing, connecting with the people you care about - that's what makes a webcam different. And Logitech HD webcams are about sharing your life - but bigger, better, brighter, smoother. High-def yourself.
  • WIDESCREEN HD 720P VIDEO CALLS
    Make high-definition video calls on your favorite platforms like Skype . At 30 frames per second, video quality is smooth, while images are crisp, colorful and contrasted
  • YOUR VOICE IS HEARD
    The built-in noise-reducing mic makes sure your voice comes across clearly, even if you're in busy surroundings
  • LOOK YOUR BEST
    Even if you're video calling or recording in dim surroundings, the C270 adjusts to the lighting conditions to produce brighter, contrasted images
  • FIRMLY FIXED
    The webcam comes with a universal clip. You can either attach it securely to your screen or sit it on a shelf
  • FLEXIBILITY THAT GOES BEYOND BUILT-IN
    Small, agile and adjustable, the C270 Webcam brings a whole new angle to video calling
Logitech HD Webcam C270 - webcam
Webcam
Audio
Yes: built-in microphone
Wired
Camera
Max Resolution
1280 x 720
USB 2.0
1 - USB cable - 1.5 m
720p HD video calls, Logitech Fluid Crystal Technology, Skype compatible
Webcam
Audio Support
Wired
Camera
Max Digital Video Resolution
1280 x 720
Computer Interface
USB 2.0
1 x USB cable - 1.5 m
Software Included
Drivers & Utilities, Logitech Vid HD
Microsoft Windows 7, Google Chrome OS, Windows 8, Windows 10, Apple MacOS X 10.10 or later
System Requirements Details
1 GHz - RAM 512 MB - HD 200 MB
