Logitech  MX Master 2S Mouse Laser 7 Buttons
Quicklinx: D1D4WS00 Mfr#: 910-005139
The ultimate precision mouse for power users powers up for an entire day in just three minutes. Harness the power of Logitech Flow and seamlessly move content between three computers. Scroll through documents and web pages faster and easier with the speed-adaptive scroll wheel. A sculpted, hand-crafted shape ensures comfortable hand and wrist support.
  • EFFORTLESS MULTI-COMPUTER WORKFLOW
    Unleash the potential of MX Master 2S by using Logitech Flow, for the smoothest workflow between computers. Move your mouse cursor across up to three computers and even copy/paste text, images and files from one computer to another
  • TRACKS ON ANY SURFACE
    A premium mouse deserves the best quality tracking. So we designed the MX Master 2S with a brand new 4000-DPi precision sensor that tracks on virtually any surface, even glass
  • FAST RECHARGING
    Plug MX Master 2S into your computer with the micro-USB charging cable and in just 3 minutes, it will be charged up and ready to power you through your entire day. A full charge lasts over 70 days
  • HYPER-EFFICIENT SCROLLING
    Scroll through long documents or web pages faster and easier. The speed-adaptive scroll wheel auto-shifts from click-to-click to hyper-fast scroll. A stroke of the thumb wheel, and you're scrolling side-to-side
  • EASY-SWITCH AND DUAL CONNECTIVITY
    Connect MX Master 2S via the included Logitech Unifying Receiver or Bluetooth low energy technology. Thanks to Logitech Easy-Switch technology, pair up to 3 devices and easily switch between them with the touch of a button
  • HAND-SCULPTED FOR COMFORT
    A perfectly sculpted, hand-crafted shape supports your hand and wrist in a comfortable, natural position. Experience fine-motion control and fluid experience with well-positioned buttons and wheels
Logitech MX Master 2S - mouse - Bluetooth, 2.4 GHz - graphite
Mouse
Wireless - Bluetooth, 2.4 GHz
Graphite
8.57 cm x 12.6 cm x 4.84 cm
145 g
Wireless Receiver
Logitech Unifying receiver
Movement Detection Technology
Laser
Buttons Qty
7
Movement Resolution
4000 dpi
Performance
Realtime sensitivity switching 200 - 4000 dpi
Logitech Darkfield Laser Tracking, Logitech Unifying receiver
Microsoft Windows 7, Apple MacOS X 10.10 or later, Windows 8 or later, Windows 10 or later
Mouse
Wireless Receiver
8.57 cm
12.6 cm
4.84 cm
145 g
Graphite
Input Device
Wireless
Bluetooth, 2.4 GHz
Max Operating Distance
Up to 10 m
Laser
Buttons Qty
7
Movement Resolution
4000 dpi
Performance
1 x USB - 4 pin USB Type A
Micro-USB cable
Lithium polymer
500 mAh
Run Time (Up To)
70 days
