Product
LiteOn 8x Internal Slim DVD-RW Black OEM
Quicklinx: BY5DWS00 Mfr#: DS-8ACSH
Drive Type: DVD writer
Enclosure Type: Internal
Interface: Serial ATA
Type: Disk drive
More than 50 in stock
£10.49 ex VAT
£12.58 inc VAT
DS-8ACSH is a multi-function drive with power saving, slim size and ultra-light weight that it meets notebook computer as well as all kinds of compact or external applications.
  • SATA interface. 12.7mm height for notebook computer use
  • High efficient power saving modes and ACPI compliant
  • Fast access time and high data transfer rate, could be vertical mounted (optional)
  • DVD+R /DVD+RW /DVD-R /DVD-RW /DVD+R9/ DVD-R9/ DVD-RAM /DVD-ROM / CD-R/ CD-RW /CD-ROM combination drive
  • SMART-BURN1 avoiding Buffer Under Run error, Automatically adjusting writing strategy & running OPC to provide the best burning quality
  • SMART-X2 function adjusts CD-DA / VCD / DVD data extraction to a fastest allowable speed according to both data request rate from host and disk quality
  • Support Fixed packet, Variable packet, Disc-at-once, Session-at-once
  • CD read compliant: CD-DA,CD-ROM, CD-ROM/XA , Photo-CD, Multi-session, Video-CD, CD-I FMV, CD Extra, CD Plus, CD-R , and CD-RW discs with diameter of 8 or 12 cm
  • DVD read compliant: DVD single / dual layer (PTP, OTP), DVD-RW, DVD+RW, DVD-R, DVD-R multi-borders, DVD+R, DVD+R multi-sessions, DVD-R9, DVD+R9 and DVD-RAM discs with diameter of 8 or 12 cm
  • Conform to Orange Book: Part 2 CD-R Volume 1, Part 2 CD-R Volume 2 Multi Speed, Part 3 CD-RW Volume 1 (1x, 2x, and 4x), Part 3 CD-RW Volume2: High Speed, Part 3 CD-RW Volume 3: Ultra Speed.
  • Supported transfer mode: Ultra DMA mode 6
LiteOn DS-8ACSH - DVD±RW (±R DL) / DVD-RAM drive - Serial ATA - internal
DVD±RW (±R DL) / DVD-RAM drive - internal
Serial ATA
12.8 cm x 12.6 cm x 1.27 cm
170 g
Optical Storage
DVD±RW (±R DL) / DVD-RAM - 5.25" x 1/6H (Slim Line)
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 8x (DVD±RW) / 5x (DVD-RAM)
Buffer Underrun Protection
SMART Burn
Media Load Type
Tray
Serial ATA
12.8 cm
12.6 cm
1.27 cm
170 g
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Write Speed
Supported Recording Modes
Multisession, disc-at-once, track-at-once, packet writing, session-at-once, restricted overwrite, random access write, incremental recording, overburning, Layer Jump Recording (LJR)
Supported Media Formats
CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM, CD+G (Karaoke CD)
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Media Load Type
Tray
Access Time
130 ms (CD), 130 ms (DVD-RAM), 130 ms (DVD)
Buffer Size
0.5 MB
SMART Burn
SMART-X, SMART-BURN
Video CD
1 x SATA 1.5Gb/s - 13 pin Slimline Serial ATA
Compatible Bay
5.25" x 1/6H (Slim Line) - front accessible
MTBF
60,000 hour(s)
UL, TUV, BSMI, EN 60950, EN55022, IEC 60950, EN55024, CISPR 22, CB, IEC 60825-1, FCC CFR47 Part 15 B, EN 60825-1, CNS 13438, DHHS 21CFR (J)
Linux, Microsoft DOS 6.0 or later, Microsoft Windows 2003, Microsoft Windows Vista / XP / 7 / 8, Windows 8.1
5 °C
50 °C
10 - 80% (non-condensing)
Sound Emission
47 dB
Type: Disk drive
Brand: LiteOn
Price Range Ex VAT: 0 - 50
