Conventional disinfectants are effective for a short period only, FIGHT THE HYGIENE GAP with LIQUIDNANO™
Steri-Wipe® simple, scientific long term protections. PREVENTING RECONTAMINATION FOR UP TO 10 DAYS.
- Tested and proven as EFFECTIVE AGAINST 181+ Bacteria including HIV, Ebola, Influenza & Coronavirus INCLUDING COVID19
- Prevents recontamination to keep device germ free for UP TO 10 DAYS (ASTM E2180)
- The ONLY way to plug the hygiene gap and protect against immediate recontamination
- Just ONE WIPE cleans and protects your whole device
- Trusted by hospitals
- Creates oleophobic effect which improves with every application
- Kills pathogens (Bacteria, Viruses, Fungi)
- 4 pack – protecting 1 device for 1 month
USING NANO-TECHNOLOGY TO CLOSE THE HYGIENE GAP
Conventional disinfectants are effective immediately but this only last for a short period after application. Liquidnano Steri-Wipe surface disinfectant takes a completely different approach and in so doing closes the HYGIENE GAP that arises between disinfection cycles.
Steri-Wipe uses a semi-permanent nano scale layer of Silica Dioxide (SiO2) better known as Liquid Glass to protect the surface. The technology used is the sol-gel process that develops a solid gel phase on the basis of a liquid phase. The biocides used to kill germs are embedded in the porous structure of the developing sponge-like sol-gel and are washed out again when coming into contact with water (bacteria, enveloped viruses and fungi are always surrounded by a water shell).
With the continued application of the LiquidNano™ STERI-WIPE coating, a super thin layer of anti-pathogen Nano scale liquid glass is deposited on the surface.
After drying, this active layer will continue to kill the pathogens which are deposited on the surfaces; in addition the surface becomes easy-to-clean. This easy-to-clean characteristic increases over the following months as each application will create a slightly thicker deposit of active liquid glass.
- LIQUIDNANO Steri-Wipe - cleaning wipe
- Product Type
- Cleaning wipe
- Packaged Quantity
- 4 (specifications are for single item)
- Protection
- Antimicrobial
- Packaged Quantity
- Product Type
- Cleaning wipe
- Protection
- Antimicrobial
