Linx 8" Tough Tab with Barcode Scanner Black Windows 8.1 Pro
Quicklinx: BVNSWS00 Mfr#: LINX8TT/HS
  • Atom
  • Windows 8.1 Pro
  • Bluetooth 4.0
  • IEEE 802.11n
Linx Tough Tab 8 with Barcode Scanner.
Designed to be used in a variety of extreme environments, the Linx Tough Tab 8 is the perfect tablet to withstand everything that your business can throw at it. Powered by a Quad-Core Intel® processor and Windows® 8.1 Pro operating system, the IP-67 rated tablet can withstand submersion in water, dusty environments and can integrate seamlessly into your business to give you complete control and visibility over every department.
Built-in Stylus.
A discreet built-in capacitive stylus provides precision navigation and is designed to aid the function of any workforce.
Impact Protection.
Rigorously designed and drop tested to IEC-60068232 standards up to 1.2M, the Tough Tab 8 is protected from accidental bumps with reinforced edge and corner protection.
IP67 Certified.
For complete peace-of-mind, IP67 certification ensures that the device is totally protected against dust and can withstand immersion into liquids up to a depth of 1 metre.
Connectivity assured.
Always keep connected wherever your team is based with Bluetooth 4.0, a 3G micro-SIM card slot and Wi-Fi 802.11 b/g/n connectivity. GPS tracking lets your team use location-based apps for increased accuracy and security wherever they are.
Integrated barcode scanner.
With built-in barcode scanning, look to the Linx Tough Tab 8 as the perfect solution for your business. Work faster, more efficently and more effectively.
Easy-hold hand strap.
The Linx Tough Tab 8 easy-hold hand strap has a fully removable back plate that securely screws into the tablets main body. With 360-degree rotation, users can position their tablet in either vertical or horizontal orientation for ease of use.
  • Connectivity ensured
    Always keep connected wherever your team is based with Bluetooth 4.0, 3G ready SIM slot and Wi-Fi 802.11 b/g/n connectivity. GPS tracking lets your team use location-based apps for increased accuracy and security wherever they are.
  • Integrated barcode scanner
  • Built-in stylus
  • Easy-hold hand strap
    The Linx Tough Tab 8 Easy-hold hand strap has a specially installed back plate that securely screws into the tablet. With a 360-degree rotation, users can position their tablet in either vertical or horizontal orientation for ease of use. Constructed from a mix of nylon and neoprene the hand strap material is designed for prolonged use, adding durability and comfort with a simple velcro fastening for adjustability.
  • Integrated RFID
    With the addition of RFID (Radio-frequency identification) into your business workflow, the Tough Tab 8 becomes an indespensible team member, tracking and reading RFID data with pin-point accuracy and seamlessly integrating into your business environment to improve productivity and stock control.
Linx Tough Tab 8 - 8" - Intel Atom - Z3735F - 2 GB RAM - 32 GB eMMC - 3G
Tablet - no keyboard
Operating System
Win 8.1 Pro
Intel Atom Z3735F / 1.33 GHz, up to 1.83 GHz / 2 MB Cache
2 GB DDR3L
Storage
32 GB eMMC
Display
8" touchscreen 800 x 1280 / WXGA
Graphics
Intel HD Graphics
Integrated Webcam
802.11b/g/n, Bluetooth 4.0
Wireless Broadband (WWAN)
3G
Up to 7 hours
Barcode reader
23.5 cm x 14.7 cm x 2.2 cm
780 g
Environmental Standards
- EPEAT Climate+
Operating System
Windows 8.1 Pro
Processor / Chipset
CPU
Max Turbo Speed
1.83 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
RAM
2 GB
DDR3L SDRAM
Storage
Main Storage
32 GB eMMC
Display
8" - IPS
Touchscreen
Yes (10-point multi-touch)
Resolution
800 x 1280 (WXGA)
Widescreen
Image Aspect Ratio
16:10
Image Brightness
380 cd/m²
Colour Support
16.7 million colours
Corning Gorilla glass
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Resolution
5 Megapixel (rear)
Camera Features
Autofocus
Sound
Speakers, microphone
Codec
Realtek ALC5640
Communications
Wireless
Miracast, Wi-Fi Direct
Generation
3G
GPRS, EDGE
Controller
Huawei MU739
Navigation
Receiver
GPS/GLONASS
Lithium polymer
Installed Qty
1
8000 mAh
Run Time
Up to 7 hours
Connections & Expansion
Slots
1 x Micro-SIM card (1 free)
Interfaces Details
Micro-USB 2.0 , Headphone output
Memory Card Reader
Yes (SDHC Card, SDXC Card)
Integrated Options
Barcode reader
Drop-resistant, capacitive touch screen, 128-bit AES security
Stylus, hand strap
EMC, RoHS, IP67, LVD
780 g
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
