Linx Tough Tab 8 with Barcode Scanner.
Designed to be used in a variety of extreme environments, the Linx Tough Tab 8 is the perfect tablet to withstand everything that your business can throw at it. Powered by a Quad-Core Intel® processor and Windows® 8.1 Pro operating system, the IP-67 rated tablet can withstand submersion in water, dusty environments and can integrate seamlessly into your business to give you complete control and visibility over every department.
Built-in Stylus.
A discreet built-in capacitive stylus provides precision navigation and is designed to aid the function of any workforce.
Impact Protection.
Rigorously designed and drop tested to IEC-60068232 standards up to 1.2M, the Tough Tab 8 is protected from accidental bumps with reinforced edge and corner protection.
IP67 Certified.
For complete peace-of-mind, IP67 certification ensures that the device is totally protected against dust and can withstand immersion into liquids up to a depth of 1 metre.
Connectivity assured.
Always keep connected wherever your team is based with Bluetooth 4.0, a 3G micro-SIM card slot and Wi-Fi 802.11 b/g/n connectivity. GPS tracking lets your team use location-based apps for increased accuracy and security wherever they are.
Integrated barcode scanner.
With built-in barcode scanning, look to the Linx Tough Tab 8 as the perfect solution for your business. Work faster, more efficently and more effectively.
Easy-hold hand strap.
The Linx Tough Tab 8 easy-hold hand strap has a fully removable back plate that securely screws into the tablets main body. With 360-degree rotation, users can position their tablet in either vertical or horizontal orientation for ease of use.
Connectivity ensured
Always keep connected wherever your team is based with Bluetooth 4.0, 3G ready SIM slot and Wi-Fi 802.11 b/g/n connectivity. GPS tracking lets your team use location-based apps for increased accuracy and security wherever they are. -
With built-in barcode scanning, look to the Linx Tough Tab 8 as the perfect solution for your business. Work faster, more efficently and more effectively. -
Built-in stylus
A discreet built-in capacitive stylus provides precision navigation and is designed to aid the function of any workforce. -
The Linx Tough Tab 8 Easy-hold hand strap has a specially installed back plate that securely screws into the tablet. With a 360-degree rotation, users can position their tablet in either vertical or horizontal orientation for ease of use. Constructed from a mix of nylon and neoprene the hand strap material is designed for prolonged use, adding durability and comfort with a simple velcro fastening for adjustability. -
Integrated RFID
With the addition of RFID (Radio-frequency identification) into your business workflow, the Tough Tab 8 becomes an indespensible team member, tracking and reading RFID data with pin-point accuracy and seamlessly integrating into your business environment to improve productivity and stock control.
- Linx Tough Tab 8 - 8" - Atom Z3735F - 2 GB RAM - 32 GB SSD
- Product Type
- Tablet - no keyboard
- Operating System
- Win 8.1 Pro
- Processor
- Intel Atom Z3735F / 1.33 GHz (1.83 GHz) / 2 MB Cache
- Memory
- 2 GB DDR3L
- Storage
- 32 GB - eMMC SSD
- Display
- 8" touchscreen 800 x 1280 / WXGA
- Graphics
- Intel HD Graphics
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0
- Wireless Broadband (WWAN)
- 3G
- Battery
- Up to 7 hours
- Barcode reader
- 23.5 cm x 14.7 cm x 2.2 cm
- 780 g
- Product Type
- Operating System
- Windows 8.1 Pro
Processor / Chipset
- CPU
- Max Turbo Speed
- 1.83 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 2 GB
- Technology
- DDR3L SDRAM
Storage
- Main Storage
- 32 GB SSD - (eMMC)
Display
- 8" - IPS
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 800 x 1280 (WXGA)
- Widescreen
- Image Aspect Ratio
- 16:10
- Image Brightness
- 380 cd/m²
- Colour Support
- 16.7 million colours
- Corning Gorilla glass
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Camera
- Resolution
- 5 Megapixel (rear)
- Camera Features
- Autofocus
- Sound
- Speakers, microphone
- Codec
- Realtek ALC5640
Communications
- Wireless
- Miracast, Wi-Fi Direct
- Generation
- 3G
- Technology
- GPRS, EDGE
- Controller
- Huawei MU739
Navigation
- Receiver
- GPS/GLONASS
- Technology
- Lithium polymer
- Installed Qty
- 1
- Capacity
- 8000 mAh
- Run Time
- Up to 7 hours
Connections & Expansion
- Slots
- 1 x Micro-SIM card (1 free)
- Micro-USB 2.0 , Headphone output
- Memory Card Reader
- Yes (SDHC Card, SDXC Card)
- Integrated Options
- Barcode reader
- Drop-resistant, capacitive touch screen, 128-bit AES security
- Included Accessories
- Stylus, hand strap
- EMC, RoHS, IP67, LVD
- 780 g
