Next Generation Wireless Technology
Connect and upgrade your laptop or desktop computers to the newest, most powerful wireless-AC technology.
Ultimate Wireless Speed and the Power of Dual-Band
Up to 867 Mbps speed on Wireless-AC 5 GHz band or up to 300 Mbps speed on Wireless-N 2.4 GHz band
HD Video and Gaming Ready
Stream HD video and online gaming simultaneously throughout your home.
Peformance Investment Protection
Compatibility with Wireless-A (802.11a), Wireless-B (802.11b), Wireless-G (802.11g), Wireless-N (802.11n) and Wireless-AC (802.11ac) Wi-Fi Standards.
Wi-Fi Security
Supports up to 128-bit encryption (WEP, WPA and WPA2).
Easy Setup with Router or Access Point
Support WPS (Wi-Fi Protected Setup) button for easy connection with wireless router or wireless access point.
Easy Computer Setup and Compatibility
Easy to use CD setup wizard and compatible with Microsoft Windows 8, 7, Vista SP1/SP2 and XP SP3.
Take Advantage of New Wireless-AC Routers, Access Points and Extenders
Compatible with all Wireless-AC 802.11ac routers, access points and extenders (Linksys, Belkin and others).
                USB plugConnect this end to any available USB port on your computer.
                Power/status LEDFlashes when there is wireless network activity.
                WPS/security LEDIndicates security status and provides feedback during Wi-Fi Protected Setup handshaking.
                Wi-Fi Protected Setup (WPS) buttonPress this button and the WPS button on your router or access point to connect your computer to the wireless network.
- Linksys WUSB6300 - network adapter - USB 3.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- 8.9 cm x 3 cm x 1.1 cm
- 17 g
- Data Link Protocol
- Wi-Fi 5
- Data Transfer Rate
- 867 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Network adapter
- Form Factor
- External
- Connectivity Technology
- Wireless
- 867 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Power, status, link/activity, WPS
- 128-bit encryption, WPS
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- Encryption Algorithm
- WPA, WPA2, WEP
- C-Tick, IC, RoHS, WEEE, iDA
- Software Included
- Drivers & Utilities
- 8.9 cm
- 3 cm
- 1.1 cm
- 17 g
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
