Linksys WRT1900ACS Wi-Fi Router AC1900
Quicklinx: C0HQWS00 Mfr#: WRT1900ACS-UK
  • IEEE 802.11n
£134.72 ex VAT
£161.66 inc VAT
With an advanced 1.6 GHz dual-core CPU and an impressive 512MB of RAM, the WRT1900ACS delivers improvements in wired, wireless, and network storage performance over its predecessor, the WRT1900AC. At speeds up to N600 + AC1300 Mbps, the WRT1900ACS meets the needs of the most demanding home Wi-Fi networks. Equipped with a four-antenna configuration, the router provides exceptional signal strength and range. Advanced users also have the option of modifying the router with open source firmware.
With a professional-grade 1.6 GHz dual-core ARM processor, the WRT1900ACS delivers faster throughput speeds and easily handles multiple data streams simultaneously. The result: better performance, particularly in today's multi-device homes.
The WRT1900ACS comes equipped with 512MB of RAM that works in tandem with the 1.6GHz CPU to move movies, music, and other large files faster. With more than double the memory of its predecessor, the WRT1900ACS improves data transfer speeds, allowing you to do more, faster.
The WRT1900ACS has four Gigabit Ethernet ports that are perfect for transferring large media libraries at speeds 10X faster than Fast Ethernet. To stream or send large files across your network at high speed, simply connect a flash drive to the USB 3.0 port or an external SATA storage device to the eSATA port. The eSATA port also serves as a USB 2.0 port.
The WRT1900ACS features four external, adjustable high-performance antennas that provide strong, reliable coverage throughout your home. The unique antenna diversity technology onboard helps your laptop, tablet, smartphone, and other connected devices achieve an optimal connection, wherever they are in your home. The antennas also enhance coverage for both 2.4GHz and 5GHz bands, keeping everyone gaming, downloading, and streaming without lag.
Designed especially for today's mobile-device households, the WRT1900ACS features Beamforming technology, which focuses wireless signals at a receiving device rather than simply sending out Wi-Fi in a general direction.
While the Linksys WRT1200AC provides an outstanding experience via Smart Wi-Fi immediately out of the box, advanced users can further modify the router with open source firmware. Developed for use with OpenWRT, an open source, Linux-based operating system, the router offers an additional layer of customization to suit your needs.
Linksys Smart Wi-Fi lets you access your network anytime, anywhere. Using your browser or the Smart Wi-Fi mobile app, you can:
  • Prioritize devices or websites for video streaming and online gaming
  • Control inappropriate or distracting content
  • Monitor network activity and speed
  • Turn Wi-Fi access on or off for any connected device
  • Create a separate, password-protected guest network
Linksys WRT1900ACS - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Network / Transport Protocol
PPTP
Stateful Packet Inspection (SPI), Wi-Fi Protected Setup (WPS), PPTP passthrough
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
AC 120/230 V (50 - 60 Hz)
12.1 cm x 7.5 cm x 2.6 cm
722.2 g
Microsoft Windows 7, Apple MacOS X 10.x or later, Windows 8.1, Windows 10
United Kingdom
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
PPTP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, 128-bit AES, WPA2-Enterprise
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac, FCC Class B certified
ARM 1.6 GHz
RAM
512 MB DDR3 SDRAM
Flash Memory
128 MB
Status Indicators
Port status, power, Internet
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , Storage: 1 x USB 2.0 / eSATA-300
Aerial
Aerial
External detachable
Antenna Qty
4
External power adapter
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
12.1 cm
7.5 cm
2.6 cm
722.2 g
C0HQ C2G 2m USB 2.0 A/B Cable - Black In Stock £3.72
C0HQ C2G 5m USB 2.0 A/B Cable - Black In Stock £4.94
C0HQ C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.13
Type: Wireless router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11ac
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Brand: Linksys
Price Range Ex VAT: 100 - 150
