Linksys WRT1200AC-UK Ultra Smart AC1200 WI-FI Router
Quicklinx: BC97WS00 Mfr#: WRT1200AC-UK
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
  • IEEE 802.11n
£97.01 ex VAT
£116.41 inc VAT
Featuring 2 adjustable antennas and a powerful dual-core CPU that delivers best-in-class AC1200 speeds and performance.
  • Engineered for ultimate performance
    Built on the foundation of original WRT's open-source heritage, the Linksys WRT1200AC delivers superior network performance for demanding users. The WRT1200AC features two external antennas, a powerful 1.3GHz dual-core ARM, and Wireless-AC to provide high-speed Wi-Fi connections with exceptional range.
  • Esata, & Gigabit ethernet ports to share files
    For competitive performance, WRT1200AC equipeed with four Gigabit Ethernet ports featuring speeds up to 10 times faster than Fast Ethernet. Using the USB port, you can add external storage devices to share content across your network, or a printer for the office.
  • Dual-band antennas and beamforming for professional-grade coverage
    To provide fast, reliable Wi-Fi coverage throughout your home or office, the WRT1200AC features two high-performance antennas engineered to enhance 2.4 GHz and 5 GHz dual-band wireless connections. With adjustable antennas and Beamforming technology delivering a focused signal to individual devices, you'll experience faster network speeds, better range, and reduced interference from other devices for strong, stable Wi-Fi connections.
  • Fast processor to surf, stream, & game simultaneously
    With a professional-grade, ARM processor, the WRT1200AC is one of the fastest Wireless-AC routers in its class. Unlike standard single-core processors which have to switch between data streams and aren't as suited for multitasking, a dual-core processor can handle multiple data streams simultaneously. The result: better efficiency and performance, particularly in today's multi-device world.
  • Open source ready
    While the Linksys WRT1200AC provides an outstanding experience via Smart Wi-Fi immediately out of the box, advanced users can further modify the router with open source firmware. Developed for use with OpenWRT, an open source, Linux-based operating system, the router offers an additional layer of customization to suit your needs.
Linksys WRT1200AC - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Firewall protection, Stateful Packet Inspection (SPI), parental control, Wi-Fi Protected Setup (WPS), reset button
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Apple MacOS X 10.5.8, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.6.1, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks
United Kingdom
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Encryption Algorithm
WPA, WPA2
ARM 1.3 GHz
Status Indicators
Power, LAN, wireless, USB, WPS, Internet
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , Storage: 1 x USB 2.0 / eSATA-300
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
1 x network cable
United Kingdom
OS Provided
OpenWrt
Software Included
Smart Wi-Fi
10 - 80% (non-condensing)
Type: Wireless router
Standards: Gigabit Ethernet
Standards: IEEE 802.11n
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11ac
Speed: 1.3Gbps
Brand: Linksys
