Enjoy fast wireless connectivity for your home or home office. The Linux-based Wireless-N Broadband Router with Storage Link is designed to deliver plenty of speed and coverage, so multiple users can go online, transfer large files, print, and stream stored media - all at once, all without wires.
The speed and bandwidth of Wireless-N, today's most advanced wireless technology, makes it easy for multiple users to share Internet access, files and printing. Enjoy media-intensive activities like gaming, video and Voice-over-IP phone calls - all at once, with less lag and performance degradation. Achieves faster speeds when used with Wireless-N enabled devices, but is fully compatible with Wireless-G and -B equipment.
Do more, faster
Enjoy fast wireless connectivity for your home or home office. The Linux-based Wireless-N Broadband Router with Storage Link is designed to deliver plenty of speed and coverage, so multiple users can go online, transfer large files, print, and stream stored media - all at once, all without wires. -
Wireless-N power
The speed and bandwidth of Wireless-N, today's most advanced wireless technology, makes it easy for multiple users to share Internet access, files and printing. Enjoy media-intensive activities like gaming, video and Voice-over-IP phone calls - all at once, with less lag and performance degradation. Achieves faster speeds when used with Wireless-N enabled devices, but is fully compatible with Wireless-G and -B equipment. -
Reliable coverage
Experience coverage you can count on, all around your home. Wireless-N's multiple in, multiple out MIMO technology actually uses the signal reflections that confuse ordinary wireless technologies to boost range and reduce dead spots. -
Storage for all
The Storage Link feature lets you connect a hard drive or flash-based USB storage device directly to your network to easily add gigabytes of storage. Access your music, video, or data files from anywhere within your network. Built-in DLNA 1.5 compatible media server streams to PCs or UPnP AV digital media adapters. -
Connect to more
Four 10/100 Ethernet ports let you connect printers, networked storage drives, and other Ethernet-enabled devices to your network, so you can access and share them from all around the house.
- Linksys WRT160NL - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
- Routing Protocol
- RIP, static IP routing
- Remote Management Protocol
- HTTP, HTTPS
- Full duplex capability, firewall protection, DMZ port, DHCP support, NAT support, MDI/MDI-X switch, SPI, MAC address filtering, VPN passthrough, 256-bit encryption, Access Point operational mode, firmware upgradable, MIMO technology, WPS
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
- 20.3 cm x 15.9 cm x 3.3 cm
- 283 g
- Microsoft Certification
- Compatible with Windows 7
- System Requirements
- Apple MacOS X 10.4.x or later, Microsoft Windows Vista / XP
- Localisation
- United Kingdom
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Routing Protocol
- HTTP, HTTPS
- Encryption Algorithm
- 128-bit WEP, WPA, WPA2
- Authentication Method
- RADIUS
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft), UL, cUL, RSS-210, IC, FCC
- Status Indicators
- Port status, power, link OK, link/activity
- WAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x 4 pin USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Gain Level
- 1.8 dBi
- Power Device
- External power adapter
- Cables Included
- 1 x network cable , 1 x USB extension cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 20.3 cm
- 15.9 cm
- 3.3 cm
- 283 g
- 0 °C
- 40 °C
- 10 - 80%
