Linksys Wi-Fi Range Extender RE6300 DB AC750
Quicklinx: C0HKWS00 Mfr#: RE6300-UK
Eliminate dead zones and boost the Wi-Fi signal from your existing router with the Linksys AC1200 BOOST EX Wi-Fi Range Extender (RE6400). The range extender features simple setup options which allow you to quickly determine optimal placement in relation to your router. It works with all Wi-Fi routers, including those from service providers, to deliver uninterrupted video and music streaming, smooth online gaming, and seamless content sharing.
This dual-band extender delivers AC1200 data transfer speeds (N300 + AC867 Mbps) for fast, uninterrupted Wi-Fi that you can enjoy in the far reaches of your home - even outdoors.
  • Up to N300 + AC433 mbps speed
    Dual band wireless range extender brings speed and reliability, wherever you are.
  • Spot Finder technology
    Easy to use, mobile-guided range extender setup to extend Wi-Fi range throughout your home.
  • Works with any router
    Works with any wireless router, including your service provider's router.
  • Cross-band technology
    Maximizes the simultaneous use of both bands for high-speed data transfer and uninterrupted streaming and gaming.
  • Simultaneous dual band (2,4+5 GHz)
    Delivers a stronger connection at a wider range than a single band, at speeds up to AC750.
  • Beamforming technology
    Optimizes performance by focusing wireless signal to connected devices.
  • Gigabit Ethernet port
    Transfer data 10x faster than Fast Ethernet, ensuring high-speed connectivity for wired devices.
  • Eliminate dead zones and boost Wi-Fi
    Easily expand your home Wi-Fi to enjoy uninterrupted streaming, smooth online gaming, and more with the Linksys AC750 BOOST Wi-Fi Range Extender (RE6300). The AC750 BOOST extends your existing Wi-Fi range up to 6,500 square feet so you can enjoy a stronger Wi-Fi signal - even outdoors.
  • Strengthens Wi-Fi connection with Dual Bands
    Stream movies, play games online, and browse the Web without interruptions, thanks to the range extender's simultaneous wireless dual bands. The AC750 BOOST features data transfer speeds up to N300 + AC433 Mbps and can also focus the Wi-Fi signal directly to your connected devices for optimal performance, thanks to Beamforming Technology.
  • Cross band technology maximizes Wi-Fi
    Cross band technology maximizes the simultaneous use of both bands for high-speed data transfer and uninterrupted streaming and gaming.
  • Advanced connectivity with Gigabit Ethernet port
    Connect a wired device such as a gaming console, Blu-ray player, Smart TV, or streaming player to your Wi-Fi network. The extender's Gigabit Ethernet port provides data transfer speeds 10x faster than a Fast Ethernet port.
Linksys RE6300 - Wi-Fi range extender
External
United Kingdom
IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
8.7 cm x 12.1 cm x 6 cm
1-year warranty
8.7 cm
12.1 cm
6 cm
United Kingdom
External
Wireless
IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Protected Setup (WPS), Cross-Band Technology, Spot Finder Technology, beamforming technology
Encryption Algorithm
WPA, WPA2, 128-bit AES
IEEE 802.11ac
Aerial
Antenna
External integrated
Antenna Qty
2
1 x 1000Base-T - RJ-45
Limited warranty - 1 year , Technical support - 90 days
C0HK C2G 2m Cat6a Shielded Patch - Blue In Stock £6.91
