Linksys Velop Network Device Mounting Bracket
Quicklinx: FD8DWS00 Mfr#: WHA0301
£17.51 ex VAT
£21.01 inc VAT
Mount your Velop nodes on nearly any wall with this sleek, space-saving wall mount. Install Velop nodes across your home or business - in hallways, kitchens, lobbies, conference rooms, and more.
  • Position Velop anywhere for whole-home Wi-Fi
  • Optimize your mesh Wi-Fi system
    Your Velop node with Intelligent Mesh Technology already helps you place your node. The wall mount makes it even easier to install your Velop mesh Wi-Fi system for optimal coverage.
  • Coil your cables for a clean look
    Built-in cable management allows you to neatly coil excess cable within the mount for a sleek, tidy look.
  • Fits Velop tri-band and dual-band nodes
    The included inserts let you adjust the wall mount to fit a range of different Velop models. The Linksys Velop Wall Mount is not compatible with Linksys Velop Wi-Fi 6 series.
  • Easy to install
    The Velop Wall Mount comes with all the screws and anchors needed for an easy, secure installation. Place the mount near an A/C outlet to supply power to your Velop node.
Linksys Velop network device mounting bracket
Network device mounting bracket
Placing / Mounting
Surface mountable, wall mountable
7.8 cm x 9.3 cm x 11.1 cm
108 g
Placing / Mounting
7.8 cm
9.3 cm
11.1 cm
108 g
Mounting Kit
Included
