Linksys SMB LACGSX SFP (mini-GBIC) Transceiver Module Gigabit Ethernet
Quicklinx: C0FPWS00 Mfr#: LACGSX
Simple, universal, Plug-and-Play Gigabit SFP+ transceiver supporting managed switches will allow customers to build a fast, reliable backbone for data centers, enterprise and service provider transport applications. Extend the connection distance significantly with this transceiver.
  • Universal Plug-and-Play compatibility
  • Fiber network expansion port
    Extend the connection distance beyond the 100 m limit of the RJ-45 port - up to 500 m for this multi-mode module.
Linksys Business LACGSX - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
500 m
Linksys LGS528, LGS528P, LGS552, LGS552P, Smart LGS318, Smart LGS318P, Smart LGS326, Smart LGS326P
Plug-in module
Wired
Cabling Type
1000Base-SX
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
500 m
1 x Ethernet 1000Base-SX - LC multi-mode x 2
70 °C
C0FP C2G 2m ST-ST 10Gb 50/125 OM3 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Aqua In Stock £10.87
C0FP C2G 2m SC-SC 10Gb 50/125 OM3 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Aqua In Stock £12.40
C0FP C2G 2m LC-LC 10Gb 50/125 OM3 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Aqua In Stock £16.07
C0FP C2G 5m LC-LC 10Gb 50/125 OM3 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Aqua In Stock £20.24
C0FP C2G 20m LC-LC 10Gb 50/125 OM3 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Aqua In Stock £20.83
