Linksys Secure Flip DVI-D KVM Switch - KVM / audio switch - 2 ports
Quicklinx: FD7LWS00 Mfr#: F1DN102F-3uk
Type: KVM / audio switch
Ports: 2
Connectivity: KVM
£268.07 ex VAT
£321.68 inc VAT
The Belkin Secure Flip DVI KVM switch enables users to securely switch between two sources while presenting information from each source at a time. The Secure Flip offers superior security and data protection by providing true data path isolation between systems and networks. The Flip KVM switch securely toggles control of video, keyboard, mouse and audio between the two sources allowing navigation by selecting the switch push buttons or controlling it remotely via remote control device. The Belkin Secure Flip DVI KVM is designed, manufactured and certified to the latest NIAP Protection Profile Ver. 3.0 standard. The latest NIAP Protection Profile ensures agencies are receiving the appropriate security for Keyboard and Pointing Devices, superior protection for DVI displays and improved audio device security.
  • Dedicated processors with emulators for every port
    Isolated port paths for video and audio to prevent data leaks between computers.
  • Unidirectional data paths
    Optical data diodes prevent peripherals from being used to breach systems.
  • Display security
    Protected display interface prevents data leakage via the monitor.
  • Peripheral management
    USB device detection prevents unauthorized peripheral usage.
  • Anti-tampering
    Internal electrical sensors render unit inoperable if opened.
  • Secure labeling
    Holographic tamper-evident product label provides visual indication and prevention of tampering.
  • Fast switching
    No keyboard or mouse delays when switching ports.
  • High retention connectors
    Semi-locking USB ports prevent accidental disconnection.
  • Secure packaging
    Tamper-evident packaging ensures product is not tampered with during transport.
Belkin Secure Flip DVI-D KVM Switch - KVM / audio switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio
KVM Users Qty
1 local user
AC 120/230 V
10.92 cm x 7.62 cm x 2.54 cm
730 g
United Kingdom
3-year warranty
P/N: F1DN104E-3EA
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 30 Hz
Status Indicators
Status
2 x DVI-D input , 2 x keyboard (USB) / mouse (USB) Type A , 2 x audio input mini-jack , 1 x DVI-D output , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x audio output mini-jack , 1 x remote control
External power adapter
AC 120/230 V
Remote control
1 x keyboard / mouse / video / audio cable - 1.8 m , 1 x keyboard / mouse / video / audio cable - 60 cm
Plug and Play, FCC, DDC, ICES, EDID compatible
United Kingdom
10.92 cm
7.62 cm
2.54 cm
730 g
Limited warranty - 3 years
0 - 80% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
P/N: F1DN104E-3EA
Ports: 2
Connectivity: KVM
Brand: Linksys
