The Linksys RE4100W Wall-Plug Simultaneous Dual-Band WiFi Range Extender allows you to easily boost the range of your existing wireless router and create a strong, reliable Wi-Fi signal for laptops and smartphones in your home. This Linksys RE4100W Wi-Fi Range Extender delivers a coverage area of up to 7,500 square feet by repeating and redistributing the signal from the router to eliminate dead zones. This Linksys RE4100W Wi-Fi Range Extender is universally compatible with all Internet routers.
Eliminate dead spots and increase existing wireless coverage
Easily boost the range of your existing wireless router and create a strong, reliable Wi-Fi signal for all the connected devices in and around your home with this Linksys RE4100W Wi-Fi Range Extender. This Linksys RE4100W Wi-Fi Range Extender delivers an increased wireless coverage area of up to 7,500 square feet by repeating and redistributing the signal from the router. This allows you to enjoy fast Wi-Fi speeds on your laptop or tablet - even if you're outside on the patio or in the backyard.
Works with any Wi-Fi router or gateway
This Linksys RE4100W Wi-Fi Range Extender is universally compatible with all Internet routers, including your service provider's router. Just connect it to your network and you can access the Internet from any device, wherever you are in your home.
Dual wireless bands for maximum performance
Thanks to dual bands (2.4 GHz and 5 GHz), this Linksys RE4100W Wi-Fi Range Extender can deliver data transfer speeds of up to N300 Mbps + N300 Mbps so you can stream videos and play online games without interference.
New innovative crossband technology
With Crossband technology, the Dual Wireless bands can now receive information on one band and transmit on the other, reducing dropped data packets and creating a stronger, more consistent signal throughout your home.
Extend your Wi-Fi range up to 7,500 feet
Using this Linksys RE4100W Wi-Fi Range Extender, you can enjoy a Wi-Fi coverage area in your home of up to 7,500 square feet. The result is a stronger, more reliable Wi-Fi signal, allowing you to stay connected on your laptop or mobile device from anywhere inside - or even outside - your home.
Ethernet ports for wired connections
Along with wireless connectivity, we equipped this Linksys RE4100W Wi-Fi Range Extender with two Fast Ethernet ports so you can create reliable wired connections to desktop and laptop computers and other Internet-ready devices.
Quick and easy installation setup
Connect the power cable. Plug in the range extender midway between your router and the area without Wi-Fi. Wait for a solid light on the cover of the range extender. Then, on a computer, phone, or tablet, connect to the Wi-Fi network "Linksys Extender Setup." Set up using the web browser.
Minimum system requirements
For range extender setup, this Linksys RE4100W Wi-Fi Range Extender requires a wireless router or access point, along with a Wi-Fi-enabled computer that has an Ethernet port and that runs the Microsoft Windows XP SP3, Windows Vista SP1 or later, Windows 7, or Windows 8 operating system or the Mac OS X Leopard 10.5.8 or later, Snow Leopard 10.6.1 or later, Lion 10.7 or later, or Mountain Lion 10.8 or later operating system.
Increase your Wi-Fi range up to 7,500 square feet
With the N600 PRO Wi-Fi Range Extender (RE4100W), you can easily expand the range of your existing wireless router. Simply plug the device into a standard wall outlet midway between your router and the area where you need Internet connectivity - say, an upstairs bedroom, hallway, office, or another remote area of your home. The RE4100W repeats the signal from the router and redistributes it to reduce wireless dead spots. -
Dual wireless bands ideal for streaming movies
Featuring dual wireless bands of 2.4 GHz and 5 GHz, the RE4100W can deliver data transfer speeds of up to N300 Mbps + N300 Mbps - perfect for streaming movies without interruptions. -
The RE4100 also features Crossband technology, which helps maximize the simultaneous use of both bands for high-speed data transfer and uninterrupted streaming and gaming. With Crossband technology, the dual wireless bands can now receive information on one band and transmit on the other, reducing dropped data packets and delivering a stronger, more consistent signal throughout your home. -
Get a stronger signal with exclusive Spot Finder technology
Linksys Spot Finder technology provides a seamless setup process and helps you determine the optimal placement of the RE4100W, allowing you to enjoy Wi-Fi even in the far reaches of your home. Using any mobile device, such as a smartphone or tablet, Spot Finder shows you where to place the range extender in relation to your existing router. Simply follow the prompts for a quick and easy setup. -
Connect speakers to stream music
Ideal for music lovers, the RE4100W sports an audio jack on the side, which lets you connect a stereo system or a speaker to the range extender and then sync the extender with your smartphone or laptop to wirelessly stream music. -
Universally compatible with Internet routers
The RE4100W is compatible with virtually any Wi-Fi router or gateway, and you won't need to adjust your router's settings when installing the extender. Simply connect the RE4100W to your current wireless network to enjoy Internet access on all your devices, from anywhere in your home.
- Linksys RE4100W - Wi-Fi range extender - Wi-Fi
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- OS Required
- Microsoft Windows 7, Apple MacOS X 10.5.8 or later, Microsoft Windows XP SP3, Microsoft Windows Vista SP1 or later, Apple MacOS X 10.6.1 or later, Apple MacOS X 10.7 or later, Windows 8, Apple MacOS X 10.8 or later, Apple OS X 10.9 Mavericks, Apple MacOS X 10.10
- 1-year warranty
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 600 Mbps
- Remote Management Protocol
- HTTP
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Power, link/activity, WPS
- Wall mountable, Wi-Fi Protected Setup (WPS), reset button, Apple AirPlay, Cross-Band Technology
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- 1 x 100Base-TX - RJ-45 , 1 x audio line-out - mini-jack
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 1 year
