Linksys LRT214-UK Wired VPN Router
Quicklinx: 9DY7WS00 Mfr#: LRT214-UK
Type: Router
Connection Type: DSL (Cable)
Standards: Ethernet, Fast Ethernet, Gigabit Ethernet
Rackmount or External: External
Hurry, only 1 left in stock!
£131.78 ex VAT
£158.13 inc VAT
Ensure high-speed, secure, and reliable network service for employees, whether they're at the office or on the road.
  • OpenVPN server support
    It allows OpenVPN clients running on employees' laptops, smartphones, and tablets to connect to the offices using two-factory authentication.
  • Integrated firewall
    Supports URL filtering and access rules that allow administrator to further regulate the traffic within the business network based on the services and source/destination IP addresses.
  • 802.1q support
    It provides separation between resources in different SSIDs/VLANs. With inter-VLAN routing, the products allow specified traffic to traverse between VLANs.
  • Intuitive web administrative interface
    Allows small business owners to deploy and manage the routers without professional IT staff onsite.
Linksys Business LRT214 - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Performance
VPN throughput (IPSec): 110 Mbps , NAT throughput: 900 Mbps
Concurrent connections: 30000
Network / Transport Protocol
PPTP, IPSec, PPPoE, DDNS
Routing Protocol
RIP, static IP routing, RIPng
Remote Management Protocol
SNMP, HTTP, HTTPS
Firewall protection, DMZ port, DHCP support, NAT support, auto-negotiation, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, MAC address filtering, IPv6 support, URL filtering, firmware upgradable, Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, DNS proxy, port forwarding, reset button, port triggering, DHCP relay, IPv6-to-IPv4 gateway, tagged VLAN, VPN Server, IGMP proxy, security lock slot (cable lock sold separately)
IEEE 802.1Q, UPnP
19.1 cm x 13 cm x 4 cm
722.2 g
United Kingdom
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
SNMP, HTTP, HTTPS
IEEE 802.1Q, UPnP, FCC Class B certified
Status Indicators
Port status, system, WAN, LAN, DMZ, diagnostic, VPN
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , DMZ: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter
United Kingdom
19.1 cm
13 cm
4 cm
722.2 g
Limited warranty - lifetime
10 - 85% (non-condensing)
9DY7 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.19
9DY7 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.62
9DY7 C2G 2m Cat6a Shielded Patch - Blue In Stock £7.13
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Brand: Linksys
Price Range Ex VAT: 100 - 150
