Linksys LGS552P-UK 48-Port Managed PoE Switch (2 SPF 10G)
Quicklinx: 9DY5WS00 Mfr#: LGS552P-UK
Type: Gigabit Ethernet
Ports: 52
Data Transfer Rate: 1Gbps
Managed: Yes
POE: PoE+
£746.07 ex VAT
£895.28 inc VAT
Add secure, reliable, powerful switching to your growing business network, with state-of-the-art features and performance including Gigabit speed, enhanced security, Power over Ethernet Plus, and advanced traffic management ideal for real-time voice and video applications.
  • Quality of Service (QoS)
    Numerous QoS features ensure that traffic is prioritized properly to deliver the best possible user experience for real-time applications like voice and video along with bandwidth intensive graphic / video file uploads and downloads. Advanced QoS provides per flow base policer and rate limit to enforce SLA requirement.
  • Power over Ethernet Plus (PoE+)
    Linksys Managed Switches support IEEE 802.3at (PoE+) standards and provide up to a 30W power budget per Gigabit Ethernet port while offering IEEE 802.3af (PoE) backward compatibility. PoE+ capability simplifies and reduces complex technology deployments such as IP telephony, wireless AP, and IP surveillance by allowing you to connect and power network endpoints over a single Ethernet cable at a lower cost.
  • Network security
    Unauthorized access to the network and mission-critical data is a constant concern. Linksys Managed Switches offer to secure networks through port authentication and MAC-based port security, requiring clients to authenticate themselves before any data is passed. Advanced DHCP snooping and IP-MAC-Port binding functions ensure network integrity and help prevent network attacks.
  • Network expansion
    Linksys Managed Switches include features for quickly expanding and growing your network. Multiple high-bandwidth trunks between switches enhance availability and redundancy. Spanning Tree Protocol (STP) and Storm Control features help control planned or inadvertent cable loops, so you can confidently build a mesh of switches and quickly expand your network to support your growing workforce. With additional Gigabit or 10-Gigabit uplink SFP/SFP+ fiber-optic port expansions for servers and data centers, Linksys Managed Switches provide an ideal combination of business scalability and affordability.
Linksys Business LGS552P - switch - 52 ports - Managed - rack-mountable
Switch - 52 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP + 2 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
375 W
Performance
Forwarding performance: 104.16 Mpps , Switching capacity: 140 Gbps
Active VLANs: 1000 , QoS hardware entries: 4
MAC Address Table Size
16K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 2c, HTTP, HTTPS, TFTP
DHCP support, ARP support, IGMP snooping, Syslog support, port mirroring, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), STP Root Guard, DHCP relay, Link Aggregation Control Protocol (LACP), DHCP client, static routing, Class of Service (CoS), 802.1x authentication
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3at, IEEE 802.3az
AC 100/230 V (50 - 60 Hz)
44 cm x 35 cm x 4.445 cm
5.32 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
375 W
Performance
16K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
Authentication Method
RADIUS
RAM
128 MB
Status Indicators
System, PoE, link/activity
48 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP , 2 x 10GBase-X SFP+
Internal power supply
United Kingdom
44 cm
35 cm
4.445 cm
5.32 kg
Limited warranty - lifetime
50 °C
10 - 90%
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 90% (non-condensing)
9DY5 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
9DY5 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.20
9DY5 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.67
9DY5 C2G 2m Cat6a Shielded Patch - Blue In Stock £7.16
Ports: 52
Managed: Yes
POE: PoE+
Brand: Linksys
Price Range Ex VAT: 500 - 750
